Question about HP OfficeJet 6110 All-In-One InkJet Printer
Can't scan document
I purchased a second hand HP officejet 6110 printer, I download this software from web. but wonder why I can;t scan my document by using HP6110 printer
  • pwabby Feb 04, 2009
    I notice that I don't have HP solutio application on my hp printer program, how do I download this software from the net? thanks.
    Problem Solver:
  • 13 Answers
You have to download from hp the compatibility pack to Internet Explorer 7 and HPdirector software(if you are using xp)
see on the right of this page,under red warning
Posted on Mar 21, 2009
Did you open the HP solutions application first. OPen up the application and you will see a scan document option. You can do it from your computer, but that program has to be open..hope that helps
Posted on Jan 23, 2009
Can I scan 5 documents and make them one PDF file with this scanner? HP all in one 6110
YES, I have the same scanner. You have to have adobe acrobat full version, not just the reader. with the full version you can create .PDF's with as many pages as you want. You can also combine two .PDF's into one if you wanted but you will need to purchase the full version of adobe acrobat.
Apr 24, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Does anyone know if Windows 7 fixes the problem that Vista users have with HP Officejet 6110 scan function? ie: not respondind to buttons on 6110 when trying to scan.
yes it will fix the issue :
Need to download the driver for Windows 7 from the hp's website.
Click on the below given link it will help you download the software :
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
Also try to print
Also try to scan from the scan button on the printer
This should resolve your Issue
Oct 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
It will not scan, prints, copy, but not scan
hi... have some idea about your problem... maybe u should try this... try to install your twain driver of your printer first then next is the scanner driver... then you'll fing what will happen next... thank you very much...
Jul 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6100 all in one
I have also misplaced the original CD that came with mine. With a new computer, I had to download the printer driver from the HP site (I chose the "corporate installation" one because it was the most up-to-date).  Unfortunately, the neat software that helps to scan documents and images does not come with this downloaded software. Even if you purchase a new CD from HP, they tell you that it does not bring the entire enchilada --the scanner software is not included. However, you can still use Windows scanner routines to scan images. To scan documents as pdf files, I ended up downloading Scan2pdf, a freeware. You can easily find it with a search engine. Good luck.
As for a power cord, I know it is far from a standard one. Is it a proprietary plug? My hunch is that it is common among other officejet products.
Mar 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scan Problem with HP Officejet 6110 All-in-one
Once try to scan from the scanners and camera wizard to check the two way communication between the computer and the all-in-one.
  1. Verify that the all-in-one product power is turned on and the printer cable is properly connected.
  2. Click Start .
  3. Click Programs .
  4. Click Accessories .
  5. Click Imaging .
  6. From the Imaging application, click File , and then click Select Device .
  7. Select the HP all-in-one device from the TWAIN source list.
  8. Click File , and then Acquire Image . Imaging for Windows will scan from the all-in-one product using TWAIN software instead of the HP software.
If you are able to scan by performing the above steps then search for the file hpqscnvw.exe and try to scan from there.
If you are not able to scan even from the above steps, once refresh the USB cable and then try to scan again.
if you are able to scan from that file then try to scan from HP Director, if the issue persists then create a shortcut icon for that file and then try to scan else uninstall the software and reinstall.
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
6110 Scan problem
Please click on the web link given below and download the printer software.
This should fix your issue.
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
Here is the other web link.
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Mac OS 10.5 Leopard
I was able to get my 6110 to scan by downloading HP_Installer_PSC7100_v9.7beta.dmg .  I saw this on XLR8YourMac for another HP multi-function and on a lark I decided to try it.  During the installer it won't detect the 6110, but you are able to "Skip" to the next step until it's installed.  Then, launch "HP All-in-One Device Chooser" and you will see the 6110 listed.  After I choose it there, I was able to use "HP Scan Pro" with the 6110.  I've not really tested the rest of the applications.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
120 people viewed this question
Ben Johnson
