Question about Lexmark X2500 All-In-One Printer
How do i print labels with my printer - Lexmark X2500 All-In-One Printer
  • 2,229 Answers
First you need a word processing program like MS Word, WordPerfect, OpenOffice, etc.
They all have functions (usually under the menu item like "tools") that will allow you to print labels.
They should also ask you to set up your labels and will ask you what manufacturer (like Avery) the labels are and what number they are.
Each of these programs has a "help" function where you can ask specifically how to perform the task.
Posted on Jan 23, 2009
The printer prints one label and skips another one
First, I need to admit it. This is the worst printer I have ever used. I had all kond of troubles with it.
The skipping labels problem was my misery for 2 days to. I had to find out that my labels were falling out of the printing area generating a new page (label). Go back fix your width. Make sure your label fits one page (label). Print again. That's what I did. Good luck.
Mar 27, 2014 | Zebra LP 2844 Thermal Printer
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
HELLO: PRINTS ONE LABEL
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Label Printing Issue
Send the shipping label to the printer first in your software.
This isn't a printer issue. It only prints stuff in the order received.
Steve W.
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Printing addresses on labels
did set the parameters in the system before printing labels you can make a new printer control in printers section to only be label printed with the same printer you use
when you goto print click on the new print control that you have set for labels this way your software wont get the big confusion of paper or labels
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Lexmark X2500 All-In-One Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
