Question about Nikon Coolpix 4600 Digital Camera
My 2G memory card says it is write protected, how do I solve this
I have a new Nikon 4600 camera
  • 153 Answers
Remove the memory card and move the slider on the side of the memory card to the unlocked position.
Posted on Feb 02, 2009
Memory card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 22, 2014 | Nikon Coolpix 4600 Digital Camera
Tip
Shows memory card write protected.....?
When I'm using any memory card, it shows write protected. Y does it happening so...? Ma memory card is fresh & not locked or somthing like that & it works in other devices...
Please help me sombody...
Thanks
By Jeffrey Paul Rodrigues...
on Dec 15, 2008 | Nikon Coolpix 4600 Digital Camera
Coolpix 4600 Digital Camera: memory card is write protected...
Good day,
This is a common problem that many people experience with their SD Cards when they are "Locked".
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 18, 2010 | Nikon Coolpix 4600 Digital Camera
How do I erase my memory card? Thanks, Chris
You can format your memory card using the camera's menu to "format" removes all files and reinstalls the cameras' directory to the memory card for use in the camera.
Note:- Formatting the memory card erase all the data including protected images and other file types. So, once you formatted the memory card there is no way to restore them.
Rating the solution is highly appreciated...Good Luck
Mar 03, 2010 | Nikon Coolpix 4600 Digital Camera
When turned on says memory card protected write
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 01, 2009 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 lens extended and won't turn on
Go to store and purchase a memor card reader/writer. It will allow you to put your memory card in it and download the pictures to the computer via the usb port. Make sure the reader/writer is made to accept your type of memory card.
Dec 27, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon 4600 coolpix
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 08, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon 4600
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 seconds then replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 03, 2008 | Nikon Coolpix 4600 Digital Camera
Turning on the camera
Please look at the memory card closely. If there is a write protect switch, it will give you this error. Please ensure that the write protect switch on the memory card is not in the lock, or protected position.
See more information about SD cards here.
Let me know if this helps!
Brian
Jan 08, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
