Question about Uvonair 5000 741010
Uvonair 5000 operating instructions - Uvonair 5000 741010
Oreck Air 12GU Instruction Manual
First of all, thank you very much Joe for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.oreck.com/PUG/Air-ProshieldPlus-AIR12GU-userguide.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Jan 31, 2012 | Oreck XL Professional Air Purifier
I have an Eagle 5000 air purifier. Stopped working
Just went thru this Tues. Get the top of screen in place and then push the plastic in on safety switch. I was having it push down and then slide screen in. That plastic piece is split like when you push it in, it hits 2 different heights. Instead of pushing it down get top in and push the plastic in, easy. Turned on then. Already had the switch on so it fired up soon as I pushed it in.
Jan 15, 2010 | Eagle Advantage Alpine Air Purifiers Eagle...
I need to lubricate the fan. How do I get to it?
Email to miller@healthyti.com and ask for free supplemental cleaning instructions. The cleaning instructions include detailed fan removal instructions. The cleaning instructions may be beneficial as well, since proper cleaning is critical to satisfactory operation.
Aug 09, 2009 | Ecoquest Breeze AT Living Air Purifier
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
Parts for a eagle 5000
I have some parts in stock and can order ones that you need.
Becky
716-652-6053
horninghealthyliving@live.com
Jul 23, 2008 | Eagle Advantage Alpine Air Purifiers Eagle...
Ionic Breeze Quadra Electrostatic Air Cleaner, Model S1637
http://www.allergybegone.com/ionbreezquad1.html
There is a manual for your purifier at this website.
It is in pdf form, free to download.
look for the sentence on the page.
it will take you to the download.
Feb 25, 2008 | Air Purifiers
Uvonair 5000 741010 Logo
64 people viewed this question
Top Uvonair Air Purifiers Experts
Are you an Uvonair Air Purifier Expert? Answer questions, earn points and help others
