Question about Garden
Removing mower blades
Does hex nut undo counterclockwise direction
    Problem Solver:
  • 16 Answers
It should be marked with a "L " if it's a backwards thread.
Posted on Jan 13, 2013
5 Suggested Answers
wadembly
  • 462 Answers
SOURCE: Can't chnge blade on Black and Decker 19"Electric
if you can try to pull up on blade as you try to loosen bolt see what happens that will sometimes help get past stripped threads
Posted on Jun 14, 2009
  • 78 Answers
SOURCE: I changed the blade mandrel from my 42 inch cut
Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
GOOD LUCK
MIKE
Posted on Oct 22, 2009
  • 16 Answers
SOURCE: Changing blades.To loosen the blades nut, which way does it turn?
hi. you dont say what make or model but I offer the following. if it's just a single bolt or nut holding the blade it will rely on a bellville type washer (dished ) or will be pegged either side of the nut or bolt, if the later try to drive the pegs down level with the mounting boss, now get a couple of friends to lift the whole deck so you can secure the nut or bolt in a vice (vise) and using both hands turn the blade itself the opposite way that you would turn the nut, this has never failed for me, if the blades counter rotate, one will be left hand thread the other right hand. bear in mind that a rotary blade spins at around 150-200 mph, every time you hit an obstruction (and you will) the blade will tighten particularly if secured with a belleville type washer. best of luck
Posted on Nov 28, 2009
al_kupchella
  • 843 Answers
SOURCE: are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Posted on Apr 23, 2010
What direction to turn nut to remove blade from an HU625AWD LAWN MOWER
normal right hand thread so counter clockwise to undo
Apr 30, 2017 | Garden
HOW DO I REMOVE THE BLADES
The blades are typically a 'right hand' thread and tighten against the normal blade rotation for safety reasons. This means they have a tendency to work themselves tighter during use. Try using a good pair of LEATHER gloves and hold the blade with one hand while loosening the bolt (or nut) with the other. To loosen, turn the bolt (nut) COUNTERclockwise.
If this is a push mower... REMOVE THE WIRE FROM THE SPARKPLUG FIRST !!!!!! Push mowers can start when rotating the blade by hand because it turns the engine over just as a crank or pullrope would.
Make sure to take note of the positioning of the cutting surfaces of the blade and re-install them correctly...many mowers have had their blades installed backwards by mistake.
Take extra care when re installing them as they will now be SHARP !!!!!
Mar 08, 2015 | Garden
To remove the circular saw, which way do you turn the nut hold the blade on the saw?
For any saw blade or grinding wheel, the rule is this. Pushing against the points of the teeth should be the direction that tightens the nut. So you must loosen it in the same direction that the blade spins. For example, if your saw blade is on the right side of your saw, then the blade spins counterclockwise, and the wood pushes against blade clockwise - so you turn it counterclockwise to loosen it (which is in the same direction that the blade spins.). If the blade is on the left side of the saw, you loosen it clockwise. Good luck, Al K
May 22, 2011 | Sears Craftsman Circular Saw Blade
When changing the blades.....how do you keep them still while undoing the nut? Also.....which way do the nuts come off.....clockwise or counterclockwise?
You would either need to hold the blades with a gloved hand or wedge something between the blade end and deck to stop movement. The nuts or bolts for the blade will unscrew counterclockwise...that is....from the right to the left.
Apr 30, 2011 | Cub Cadet Garden
To remove the blade, does the bolt turn clockwise or counterclockwise?
As viewed from beneath, the bolt is loosened by turning it counterclockwise. They are generally pretty darn tight. Use a block of wood to hold the blade from rotating. A rubber mallet to encourage the wrench usually helps too. By the way, the rule for which way to loosen a bolt or nut that holds a blade by it's center is that loosening is in the same direction as the blade normally turns. This is because the work (the grass in this case) tries to resist the blade and therefore pushes against the direction the blade is turning - and that MUST be the direction that the blade would be tightened (otherwise it would be loosened in the course of using it!). This applies to lawn mowers, edgers, circular saws, grinders, etc. I have never found an exception to this rule. Good luck, Al K
Apr 12, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Black & decker mm850 can not get blade off so can replace how do I get off tried loosen clockwise and counterclockwise plates move will not loosen up
The nut is counterclockwise but will most likely take an impact wrench to remove the blade because the impact will not need the blade or spindle to be held in order to remove the nut.
Thanks,
Chad
Mar 23, 2011 | Garden
I am trying to remove 4 blades from the Sprint 375 Rover mower. they are unmovable, have not been changed for a long time. Please help me!! I am in despair. Des
remove cutter disc from pto
hold blade in vise and weld the blade bolt head to blade on the grass cutting side using welder ( this transfers heat to threads and helps ) then undo nuts while still clamped in vise
repeat for other blades
always use new blades , bolts , nuts and washers
cheers pauly46
Sep 10, 2010 | Garden
I cant get the nuts off the blades on my cub cadet do you turn them l or r
Not sure on your particular mower but most all mowers are left hand threads so you would loosen like you are tightening normally. I hope that is clear to you. lol
Sep 11, 2009 | Classic Accessories Garden
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
