Question about Nintendo Wii Console Rvl-101
I want to clean the lens of my wii game .Can u show me how to open it
Havent used our wii in about 5 years, and hooked it up today and it is telling me that there is a error reading the disc and to read the manual for troubleshooting, but we no longer have the manual to...
May be dust on the laser lens due to not being used you need to open up the console then the drive and clean the laser with a cotton bud very lightly
Jan 10, 2015 | Nintendo Wii Console
My wii will not read any of my games
You can try Nintendo's Wii lens cleaning kit. Also, some older Wii units have trouble with dual layer discs, which pack more info onto a disk (Super Smash Bros. Brawl and Metroid Prime use dual layer discs). If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit for that too.
If after cleaning its lens your Wii still can't read any disks then you'll want to contact Nintendo.
May 22, 2012 | Nintendo Wii Console
Nintendo WII will not play discc
The first thing to do is to get a lens cleaning kit from your local game store that is made to clean the wii's laser lens. Also, you should get something to clean your disks while you are there if they show any signs of being dirty. These two things are the first places to start.
Feb 04, 2010 | Nintendo Wii Fit for Wii
The Wii will not load games. I was told by a friend that it may need to be reset??
It may be a lens problem.If you have technical skills and tree-wing screwdriver open the console and clean the lens with piece of cotton and some alcohol.If this not help you need to replace the lens.
Nov 18, 2009 | Nintendo Wii Console
Nintendo Wii Console will not read disks it displays a black screen that says to remove game and shut off console.
Ii may be lens problem.If you have technical skills open the console and try to clean lens with piece of cotton and some alcohol.If not help you need to change the lens.
Nov 11, 2009 | Nintendo Wii Console
Wii disk error
If the console try to read the disk, but you only get whirring and clicking noise, ending up with a no disk, and if this happens with all disks then it is a lens problem.
Try first cleaning the Wii lens with a cleaner disk, that is the easiest thing to do.
If that does not work, the Wii must be opened to access the lens pickup directly, and clean the lens with Q-tips and isopropyl alcohol, or replace the lens pickup.
If the cleaner disk does not fix it, better to contact Nintendo calling the number listed on the user manual to see if they can cover the repair, or replace the Wii, before disassembling the console.
Mar 18, 2009 | Nintendo Wii Console
Continuous error message
you can but the official wii lens cleaner kit although its not available in the usa yet....by sending your console to nintendo of america the will probably just clean the lens..this cleaning kit is made from nintendo and is only in japan but you can order it from consoleshop.com there search wii lens cleaner kit. its about 20.00 us dollars with shipping.although the instructions are in japaneese you can go to youtube and search wii lens cleaner kit and look for one with a blond brittish guy and he show how to use...it quite easy and all games will play after cleaning. that is if that is the problem...any rate if its not its a good idea to get it
Jan 18, 2009 | Nintendo Wii Console
Dirty lense
To clean the lens accessing directly to the lens pick up you will need to disassemble the Nintendo. This operation invole risk of further damage to your WII, particularly if you are not exeperienced in servicing electronics. My suggestion is the following.
First try cleaning it with a dvd cleaner and cleaning solution, this operation involves no risk.
Check also if you are covered by guaranty, and eventually contact Nintendo to have your WII serviced.
If you want to proceed in opening the Wii, here are videos showing disassemblage procedure.
My strong suggestion remains not opening the Nintendo by yourself, unless you have done this many times on different devices.
Regards
May 19, 2008 | Nintendo Wii Console
Game cube games
Two choices. One: If your console still has a warranty, send it in for repair. Two: Open up your Nintendo Wii Console and clean the lens of the disk drive with some rubbing alcohol and a q-tip. Then put the console back together.
Dec 18, 2007 | Nintendo Wii Console
Wii wont read discs
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
160
Dec 16, 2007 | Nintendo Wii Console
Nintendo Wii Console Rvl-101 Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
