Question about Nextar MA933A MP3 Player
Changed the battery and now the power just stays on (nextar)
I can not even get it to shut off without pulling the battery out of it. I hooked it to the computer and it is not even recognizing that the mp3 is plugged in.
  • 4 more comments
  • Anonymous Feb 12, 2009
    where is the hold switch?
  • Debra Hartleib Feb 12, 2009
    this is making me so mad!! I have important files to remove and all I get is nextar on the screen!!
  • theprices Feb 13, 2009
    I am having the exact same problem. I checked the hold switch and it is not engaged.
  • Debra Hartleib Feb 14, 2009
    same here - w/ the battery out to turn it off and I am just loosing it. I have to get it working. I've tried 3 diff. computers, none recognize it - and they all used to. I can't get to the menu - just NEXTAR on the screen. Can any help?!
  • Debra Hartleib May 11, 2010
    mine has no hold switch!
  • Linde Balderas May 13, 2012
    Mine is doing the same thing. My computer doesnt recognize it either. Won't do anything except Nextar on the screen. have to remove battery to turn it off. What a piece of JUNK!
  • 8,596 Answers
Make sure the Hold switch is not engaged - then, remove/reinsert the battery
Posted on Feb 05, 2009
Light stays on charging, doesn't shut off..... Doesn't hold a charge
Hello, Pull the electric cord and let the battery run all the way down. Pull the battery out and try powering up and down on the switch without the battery in. If that works then you have a bad battery.
Oct 04, 2015 | ZAGG Apple Folio Case With Keyboard For...
The battery has been replaced but the battery still loses power and runs down once its turned off
it sounds like you have somthing staying powered up hook up battery negitive cable and then use test light on positive lead put clamp on battery positive lead and use the point on the battery if light is on bright then you have somthing staying on like glove light dome lights or even visor lights with lead still hooked up you need to touch the clamp to the point end to power down the timer system usually 20 seconds then pull clamp away from point end while staying connected with battery and cable if you loose that connection you will need to start timer power down again then while someone is keeping the connection pull one fuse at a time and notice if light goes out or dim if it does either then see what that fuse powers and it will tell you what is staying powered
Aug 17, 2013 | 1999 Ford Explorer
Even when my gps is turned off it loses battery power. How can I get it to stay charged?
You could hard wire the car power adapter for your gps to a Constant 12 volt wire and ground to prevent your gps from losing it's charge. Else you will need to plug in the car charger for your gps and charge the battery a bit before you can use it.
Oct 01, 2011 | Nextar X3 GPS Receiver
My nextar mp3 doesn't conncect
Talked to a nextar rep, if windows doesn't load the drivers, then their is something corrupt in the firmware. When I hook mine up it keeps connecting and disconnecting. So it's most likely a firmware issue that has to be fixed by nextar.
Nov 11, 2009 | Nextar MA933A MP3 Player
Fan won't shut off
Try hook up the rad fan wires to the wires that power the headlights so that when the vehicle is running the fan would come on, or even try a toggle switch. If this aint working take the car in to the mechanic. hope I could have been some assistance. Charles H
Aug 21, 2009 | 1992 Volkswagen Jetta
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
Tempature dropped car wont start
Check the voltage on your battery with a voltmeter should be at least 12 volts without any power hooked up to it.
Pull a spark plug wire off of the coil, have someone crank the starter and hold the plug wire very close to the coil (same place you pulled the wire from) to see if there is a spark. Be careful and stay away from the engine will it is cranking
Charge the battery.
Check altenator belt and connections.
warm the car or battery (can you get the car in your garage?)
Dec 25, 2008 | 1994 Dodge Intrepid
This product uses a built-in rechargeable Li-ion battery which is charged by usb power. So when you plug it into your Computer or Laptop it recharges with the power it get through the usb port. You can also buy a USB AC Charger for MP3 Players it plugs into your wall outlet and has two usb ports on the bottom to plug into. You can get on at Walmart for about $15.00 called MusicPower
There are even USB Charger for you Car as well.
Charging Section of the User Manual
This icon will be displayed at the upper left corner of the screen. The following pictures indicate the
charging status of the battery:
(1) When the battery is charging, the battery icon will be changing from an empty battery to a full battery icon to indicate the process.
(2) The following icon will replace the charging one when it is full but the power supply is not being cut off. Which is a Battery Icon with a Lighting Bolt in the center of the icon.
(3) The player will automatically shut off when the power is used up. In this case, all setting will be
You can get this information on the Nextar website below and the right hand side there section call Downloads click on the MA715.pdf.
Nov 16, 2007 | Nextar MA7151B MP3 Player
Nextar MA933A MP3 Player Logo
Top Nextar Audio Players & Recorders Experts
Robert Graf
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
