Question about Audiovox CDM-8940 Cellular Phone
HELP!!! I have no clue what to do!!!
Funny little symbol [it's a little orange phone with a blue and white "4" or something next to it.] , no sound, keeps saying "hands free" is on, light won't turn off on sub screen when phone is closed.
  • elessar17 Apr 21, 2008
    I have the same problem. This doesn't work. I can't turn off the hands free. For some reason my phone thinks its on but it isn't. Consequently I have no sound when trying to call someone. Also the hands free just turns on and off even when I don't touch my phone at all.
  • 247 Answers
I suspect your funny little symbol is a bluetooth icon. Dig down into your settings menus and try two things. First, look for a list of profiles and see if you can select one with a name like "General". Hopefully that will be enough to make the phone work. If that doesn't look for the Bluetooth settings, and try disabling Bluetooth. A.
Posted on Jul 07, 2007
  • Alastair Macleod
    Alastair Macleod Jul 07, 2007
    Last line should read:
    If that doesn't work, look for the Bluetooth settings, and try disabling Bluetooth.
    A.
SOURCE:
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
How do i connect a telephone wire to an rj11 plug. What is the order of the wires for us telephones.
dialtone should go on the green and red wires of the jack for 1 line service, yellow and black for a second line.
Depending on the type of wiring that your dealing with the color code can change. if your wiring has white wires with little dashes of color on them then the code is:
green = white/blue (mostly white with blue dashes)
red = blue/white (mostly blue with white dashes)
black= white/orange (mostly white with orange dashes)
yellow= orange/white (mostly orange with white dashes)
Oct 23, 2009 | Lands Phones
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Ibm t43 laptop's bluetooth cannot find devices
This sounds like it is exactly what I scratched my head about when I first inhereted my T43 at work. If it is, you are going to laugh at how simple it issue is. IBM in their great wisdom made a custom control for the wireless network antenna and bluetooth antenna. Try:
Hit Fn+F5. This will bring up a window where you can control turning on/off each antenna. When you turn on the bluetooth, the symbol in the system tray should turn to blue and white and the little green bluetooth light just below the screen should come on. I hope this helps.
Mar 02, 2009 | IBM ThinkPad T43 Notebook
Wires from the wall are 2(orange/white), 2(blue/white) 2(white/orange and 2(white/blue) my phone outlet which is wired has 1(black), 1(blue), 1(yellow) and 1(black. How are my wall wires to be attached...
Take a look at this image:
0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Aug 11, 2008 | Lands Phones
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Unknown icon/symbol on the screen
My w850i has a blue sqaure at the top with a cartoon woman inside with an arrow pointing forwards and i dont no what it is
May 19, 2008 | Sony Ericsson W850i Cellular Phone
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
I would like to know how to wire a rj45 socket please
There are two standards, 568A and 568B. As long as both ends of the cable are wired alike, it doesn't matter which you use.
For the 568A:
1 - White / Green
2 - Green / White
3 - White / Orange
4 - Blue / White
5 - White / Blue
6 - Orange / White
7 - White / Brown
8 - Brown / White
For the 568B, just swap the Green pair and the Orange pair.
Mar 15, 2008 | Lands Phones
Audiovox CDM-8940 Cellular Phone Logo
77 people viewed this question
Top Audiovox Cell Phones Experts
Marvin
Marvin
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
