Question about Mercury P4VM800M7 Motherboard
Help regarding CPU n Mobo
I have a p4 2.8 ghz cpu rated 400mhz fsb. can i use this cpu on new motherboards which're featuring higher fsb speeds by decreasing multiplier of cpu, this is jus a thought. can we do it? my current multiplier value is 28. im plannin to buy a new mobo with a pcie slot so was thinkin why don't i buy one which supports even future hardware. or can i find a mobo with a support for a wide range of fsb speeds? plz help me
  • 24 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
r-3
Posted on Sep 03, 2009
I want 810c marquri MB disply driver Please sent
shihora@rediff.com
Posted on Jun 16, 2008
    Scholar:
  • 36 Answers
You can usually change the bus speed in the BIOS if the MB supports it or by a jumper on the board. If thats not an option go on http://www.pricewatch.com you can find older boards there for $50. http://castle.pricewatch.com/s/search.asp?s=400mhz+fsb Hack
Posted on Jul 09, 2007
I have use intel d102ggc2 motherboard and it support 2gb ddr2 667mhz why?
The motherboard supports an Intel processor, with Up To, an 800MegaHertz Front Side Bus. (800MHz FSB)
Ram memory typically operates at half of the Processor's,
FSB frequency rate. ('Speed')
If you have a Processor with an 800MHz FSB, typically you would want ram memory that operates at 400MHz.
Ram memory at 533MHz is pushing it. Still operates at 533MegaHertz, though.
[Mega = Approximately 1 Million
Hertz stands for Cycles per Second. Named after a man with the last name of Hertz.
Frequency rate is proper speak.
'Speed' is slang brought out by Intel advertising, so everyone could understand better.
'Speed' = Frequency Rate.
DDR2 Sdram at 667MHz?
Means it can operate, UP TO ,a frequency rate of 667 Million Cycles per Second ]
I'll bet your DDR2 Sdram at 667MHz, is clocked down.
Bet it isn't running at 667MHz. More like 533MHz.
Have you used CPU-Z to find out? (Free)
http://www.cpuid.com/softwares/cpu-z.html
Need help downloading, installing, or using CPU-Z, post in a Comment.
Also will explain what you are looking at.
Regards,
joecoolvette
Jul 04, 2012 | Intel D102GGC2 Motherboard
I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Upgrading laptop CPU
Yes. Your motherboard only supports cpu's with a FSB of 400mhz. If you want to upgrade you would need a compatible cpu running 400mhz FSB. Hope this helps.
Dec 24, 2008 | Toshiba Pentium M, 1.5 GHz 715...
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Motherboard
2.2Ghz should be the fastest for your motherboard, also the cpus FSB is MAX 400Mhz
the socket is S478
only old cpus work in your motherboard new and currently being sold, core 2 duo family prosessors wont work. they all have fsb 667 or higher and your motherboard only supports up to 400fsb
here is the best cpu for your pc
http://cgi.ebay.com/Intel-P4-2-2-Ghz-CPU-400-512-478-Socket-Northwood-SL6PL_W0QQitemZ260222969857QQihZ016QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I would recommend a whole new system.
Apr 05, 2008 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
65 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
