Question about Magic Chef Dishwashers
Magic chef dishwasher model # du2000v will not drain
No the machine has not been used for a week & there is still 2" of water in it
kermit854
  • 38 Answers
SOURCE: dishwasher won't drain water
The bubbles created by the dish soap could cause poor draining, but I would think it would just cause more of a bubble problem than a draining problem...
Either way, some people would say to throw a cup of vinegar into the wash area, but I prefer to just use water.
Disconnect the drain line from the machine at the sink and route it into a 5 gallon bucket. Drain and fill the machine several times to clear the bubbles out. This will also give you the opportunity to see if the drain problem you state is a machine problem or a drain problem.
Hope this helps,
Kermit
Posted on Aug 23, 2008
rickzilla
  • 706 Answers
SOURCE: DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Posted on Sep 30, 2008
SOURCE: Where do you put the rinse agent in a magic chef dishwasher ?
there should be a place in the door.
Posted on Nov 17, 2008
  • 398 Answers
SOURCE: after drain cycle water remains in bottom of
check drain pump or solenoid
Posted on Mar 07, 2009
  • 34 Answers
SOURCE: the water does not drain still has soap in it
is the water backed up inside the dish washer
Posted on Jan 14, 2010
I have a Magic Chef dishwasher that's between 10 and 15 yrs old. The dishwasher doesn't always completely drain and leaves varying amounts of water behind.
The drain pump may be faulty or the drain pipe exiting the machine is in the wrong position allowing drain water back into the system.
Hope this solves your problem
Aug 05, 2011 | Dishwashers
I need a part # and availability on a door latch for a DU2000v
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Feb 22, 2011 | Magic Chef 24 in. DU4000 Built-in...
I have a Magic Chef dishwasher-DU2000V and lately it has been leaving soap granules and some food deposits on dishes.
check the holes on the spray arms to see if they are clogged and not giving a good spray. Also check your owners manual to see if there is a filter to clean to give you more pressure
Dec 29, 2010 | Magic Chef 24 in. DU2000 Built-in...
My chef classic dishwasher is not completely cleaning the dishes. There is no obstruction to the tablet/powder door opening, although there is a small amount of powder left at the end of the cycle. Both...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Magic Chef CDB6100 Built-in Dishwasher
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Dec 09, 2009 | Magic Chef Dishwashers
Dishwasher won't drain water
Hope this helps,
Kermit
Aug 14, 2008 | Magic Chef 24 in. DU2000 Built-in...
Dishwashers Logo
Top Magic Chef Dishwashers Experts
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
