Question about Makita 10" Miter Saw LS1030N
Makita LS1013 chop saw just started making a bad bearing noise and the elecric brake is not kicking in after the trigger is released.
  • 4 more comments
  • doug166 Jan 23, 2009
    I will try putting in new brushes first.
  • doug166 Jan 24, 2009
    The new noise could be something I've never heard before, as the brake has always worked (caused by bad brushes?), so I will try the brushes first, and if that doesn't do it I will go for the bearings.
  • doug166 Jan 25, 2009
    Daah, after replacing the brushes(old ones were fine), i discovered the problem--The dadgum bolt that holds the blade tight was just loose enough to let the blade spin down when I released the trigger. Made it sound like a bearing was out. Easy repair---yeah.
  • David Ford
    David Ford May 11, 2010
    what are you going to do about the bearing noise. I don't think that I would try and run it with a bearing that is seizing or collapsed because it will cause more damage. They are not that hard to replace and maybe where you buy your parts they will remove and press new ones on for you.
  • David Ford
    OK what do you need help with. The bearing noise is pretty easy if you have a bearing puller and a way to press it back on. Before I bought anything for the brake I would take a look at the brushes for wear and dirt in the area. Are you handy with tools if so I can help you with the disassembly of this unit. Let me know
  • Anonymous Mar 30, 2014
    How to replace the powercord for a 10 inch makita chop saw
Firung
Posted on Jan 18, 2013
  • 33 Answers
You will have to check if it is a bearing going and the electric brake may not be getting any power to it now or it could be sticking.
Posted on Feb 13, 2009
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
LS1013 Sliding Arm Saw. Why doesn't it turn on when trigger is depressed?
The trigger may have simply failed. Usually failure occurs at the least convenient time or circumstance.
Sep 05, 2015 | Makita Saws
Makita 2401b
Some mitre saws have extra windings in the field coil so a possibility is a break in this brake coil another possibility is the switch some have a contact that switches the back emf from the field coil to the brake coil when you release the trigger. And believe or it or not some times changing the brushes affects the braking have seen this a few times on the LS1013.
Mar 15, 2014 | Saws
10'' delta mitre saw making bad noise when in use
Highly unlikely the armature would warp. Both front and rear armature bearings would be my first guess.
Jul 10, 2012 | Delta Chop Saw 3 Ph, 50/60 Hz,...
How do I replace the spildle that the blade attaches to
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013/
The above link, is a complete exploded parts diagram. Below is a generic How to replace the spindle & bearings.
http://www.woodworkforums.com/f170/replacing-spindle-bearings-127932/
You will need to lock, the spindle, and use a puller, and maybe even heat to get it apart depending on how worn damage etc?
below is a wiki for another type but may help?
http://wiki.owwm.com/Default.aspx?Page=1214ArborBearings&AspxAutoDetectCookieSupport=1
A spindle repair service below.
http://www.gtsaz.com/Spindle_Rebuild_Repair.html
Apr 11, 2011 | Makita 10" Dual Slide Compound Miter Saw...
Makita LS1011- when power is turned off there is a rumbling noise coming out of the saw. I've taken it apart and can't find any broken parts. I suspect worn gears? Anyone have this problem?
Hi, Thanks for getting back to me, sorry for not making it clear but it was a 2 part question. I have a LS1011N and assumed it would have an electric blade brake like mine. When the bearings are bad it doesn't take long to also wear out the brushes so the electric brake not working full time is a symptom of that failure. Since yours doesn't have a brake then you are right in half of your guess of the gears the other half would be bearings. The only way I know to tell with the thing still assembled is to hold a screwdriver to the rear of the motor case and put your ear on the handle and run the saw and listen for the sand like sound of a bad bearing. If you don't hear anything like that it has to be worn gears and for that you have to look. Good Luck, this should Fixya!
Mar 18, 2009 | Makita 10" Miter Saw LS1030N
Makita LS1013 miter saw motor runs very slowly
Could be a bearing problem. If the bearings are dry and seizing up they will hinder the motor speed. Alternatively, if they are worn and allowing lateral movement in the motor the armature will rub against the field windings when it all magnatizes (sp?). I would investigate bearings before electrics. Hope this helps, good luck.
Nov 24, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita 10" Miter Saw LS1030N Logo
1,660 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
