Question about Miele CVA 4062 Stainless Steel
Miele cva 4060 blocked cup dispenser
How to clean coffee spouts
SpotBert
  • 231 Answers
SOURCE: miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Posted on Jan 03, 2009
SOURCE: how do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
Posted on Apr 26, 2009
SOURCE: display message - brewunit block - can not undo to
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Posted on Jan 21, 2010
  • 1089 Answers
SOURCE: In my Miele CVA 4070 the coffee dispenses out
Your dispenser spout needs to be removed and cleaned. It is getting coffee residue inside and the ports are getting smaller.
Posted on Nov 05, 2010
espressonist
  • 1711 Answers
SOURCE: my miele cva 615 the
The oils in this mud cake dry up right after the water dries up (over night) and presto you have concrete! This concrete becomes too thick to clean, so cleaning with tablets has to increase dramatically if you increase the strength of the coffee. If you leave it strong clean it weekly.
Normally you clean the brew unit with cleaning tablets every time you finish descaling. That's about once every 200-250 coffees based on the water hardness you set in the electronics. If you notice changes in the coffee water flow speed it's usually from clogging.
If you're handy get your camera. Take pictures of every step you do. Remove the brew unit. Disassemble the left top section (2 screws holding the long pipe). It compresses a 1/2" long spring. It may get away from you so be ready for it. The spring attached to a half round plastic button (valve) that looks like a rivet. Clean all brown gunk from this valve and the housing and you're cr?me will return. While you're in the cleaning mode remove the filter and clean inside under the filter. The filter is that round stainless steel screen disc with the phillips head screw in the centre.
All this is evidence that cleaning needs to be stepped up, good luck!
Posted on Jul 24, 2011
Expresso is too large
Nancy, this setting is controlled by the settings menu. You reach that by right arrowing through the different beverages/menu selections until you select "Settings".
  • In settings, scroll to "program the amount"
  • place a cup under the spout
  • select the beverage you want to program, espresso in this case
  • select start
  • select okay when the amount of water has been used
  • the machine will remember this setting for future espressos
  • the same menu structure allows you to control the amount of coffee ground, as well as the amounts for other beverages
Mar 15, 2016 | Miele CVA 4066 Stainless Steel
My miele coffee maker CVA 4070 dispensing tubes are clogged
I had this problem ... you need to remove the dispenser from the rear of the door. Then once removed clean in running water. Its a sealed unit but you can squirt high pressure water inside to dislodge the coffee sludge. When clean .. fill with water and make sure the 2 spouts drain evenly. regards
Jul 09, 2014 | Miele CVA4070 Coffee Maker
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
The coffee dispenser leaks out in other places
I've got the same problem on my CVA 4075... Coffee comes out all around the dispenser not so much through the tubes. How do I get this part out to clean it?
Mar 17, 2014 | Miele CVA4070 Coffee Maker
When I try to make a cup of coffee, only a small amount of water and coffee come out (like a shot of cappuccino) of the coffee dispenser while hot water is dispensed (simultaneously)...what could be the...
the flow pipe is blocked. you need a nylon thread to clean it out. you push it in and out a few time in the hole until it is clear. shold of come in the kit when bourght new
Sep 22, 2013 | Miele Coffee Makers & Espresso Machines
I have the coffee maker set to 2 cups. After 1 cup of coffee is dispensed I get water for the second cup then the machine keeps brewing a 3rd cup of coffee and a 4th cup of water. So instead of 2 cups of...
Yes you programmed it unaware, the machine will follow what you instruct on it. So change the program setting and try it again.
This advice will gonna help you.
Mar 31, 2011 | Miele CVA 4066 Stainless Steel
Says in the display Fault 10 and Fault 17. CVA 4060 built-in coffee machine Miele
I just switched machine off for a few hours and when started, it was OK
Sep 07, 2009 | Coffee Makers & Espresso Machines
Miele Coffee Machine won't dispense from 1 of 2 spouts
the spouts located is on door which carry the coffe to final stage to cup of coffee
thanks
Jun 05, 2009 | Miele CVA4070 Coffee Maker
Miele CVA 4062 Stainless Steel Logo
94 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
