I have a 1989 technics multi disc player model sl pc10 and was playing fine and hit a buttom i think by mistake and now will load disc but not play and few seconds goes to another disc and does same thing i thinks have some thing to do with program kept hitting buttons and it disc start to play but it had picked out a disc and a track on that disc to play i hit stop and now cant get any thing to play again it shows disc its on and track but wont play
  • 9 Answers
SOURCE: Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Posted on Dec 11, 2007
SOURCE: My Technics SL-DZ1200 will not play certain MP3
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Posted on Nov 12, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
SOURCE: Technics SL PJ27
First I think you should turn your player on and wait 5 - 40 minutes before before you start liste3ning music.
because electrolytic capasitors may be little broken and those can repair themselves but it takes a while.
Good rule of thumb is that If you don't use every day an old device
then you should give to it every time a soft start . like I mentioned earlier
turn power on and wait.
Second try to play music cd which don't have any scratches and without any copyprotections
Third Disconnect power cable
Then open device and try to clean all dust.
Look for hairs and other difficult to see objects uselly
you find at least one hair inside old cd player.
If hair is around disk spindle it maybe difficult to
remove.
Check that cd-disk makes good contact so remove even tiniest dust and hairs
between cd-player and copact-disk. It may be called spindle or what ever but
still try to clean it with Isopropyl alcohol and remove dust and filth.
Check laserlens and is there some dryed liquid stains if there is try to remove those
with Isopropyl alcohol and swabs. Don't use any force and you can tear a top of swab little longer
(about one inch) and you get swabs which are much easier to use these kind of delicate cleanings.
Lubricate every moving part with lithiumgreese don't make any mess.
This last fix is for most desperate ones.
Connect the power cable and push eject and be carefull because
you can get fatal electric shock.
Disconect power cable. You can use extension cord which have on/off powerswitch.
You can see six tiny trim pots.
First take photo of those pots so you can undo all changes.
Change only one pot and only about 1/8 of turn. Turn power on and test if you make it worst or better.
If you think you fixed the problem that is not the case ... yet.
Then you have to make finall test and play a lot of music cd:s and after that you have fixed the problem.
Make notes which cd:s and what track your player don't play properly and use those
cd:s to testing those trimpot changes.
Posted on Dec 30, 2009
  • 99 Answers
SOURCE: TEAC CD P1120 wont play
replace the loading tray belt as this also lifts the laser mechanism up to the level of the disc once loaded.
the humming sound you hear will be the motor trying to lift the mechanism up to read the disc but can't because the belt has lost its tension and is slipping.
Posted on Sep 24, 2010
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 11, 2014 | Technics SL-DZ1200 CD Player
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
I own a technics CD changer Model SL-PD 787. The system powers up showing the disc & track no. but the timer does not count down . and therefore does not play. How can I fix the problem.
Actually it's the other way around. Playback makes the counter move. Did you hit PLAY or try to seek to a track or anything to verify it 'likes' the disc?
Sep 22, 2011 | Technics Audio Players & Recorders
Cant get Technics SL-PC503 to play cds
Clean the LENS with a DISC CLEANER.
Jan 13, 2010 | Audio Players & Recorders
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
Cds
Could be the power supply not supplying enough juice to the spindle motor. Make sure it's not plugged into a "multi-plug" adapter.
Could be the spindle motor as well, or the disk sensor.
Let me know should you find something else...
Sep 21, 2008 | Technics SL-PD687 5-Disc CD Changer
Cant play
Not a solution as much as clues. I was given a SL PD588 by a friend 'cuz it stopped working. When I got around to checking it out it worked fine. Later it quit. It would rotate the turntable, load up a disc when you hit play, try to play the disc, fail, go to the next disc, etc. I pulled the cover, watched it try, could hear the lens seeking focus but the spindle wouldn't kick in and rotate. After cleaning the lens with no luck, my teenage observer decided he would spin the disc himself and maybe faster would help. Damn, if it didn't work. Sort of reminding the unit what it was supposed to do. However, not a permanent fix, 'cuz periodically it would forget and quit again. I would repeat the drill, basically giving it an assist to rotate the disc (clockwise), (maybe a few times) and it would be back functioning.
I have found the problem occurs if I leave the unit on too long, (especially in pause mode ie disc spinning, for a day or two). So I now power off when I'm thru playing discs.
Just went thru the drill again today, cover off, a little nudge to the spindle top when the disc loaded and back in business. Came to FixYa to see if anybody had an answer.
BTW, you can tell if the disc is playing correctly just by watching the track clock on the display.
Too bad the unit is so big 'cuz that means one is always stacking stuff on top of it.
Finally, and it's not like I haven't entirely dismantled this thing looking for an answer. Inside my unit is my long note on how to disassemble the mechanism.
Dec 23, 2007 | Technics SL-PD887 5-Disc CD Changer
123 people viewed this question
 Grubhead
Grubhead
