Question about Bose 3 2 1 GSX System
Bose 321 cd/dvd tray stuck closed
The DVD/CD tray on my BOSE 321 system is stuck inthe closed position. How do I open it?Stuck in closed position. Reads "Opening" then shuts off
    Brigadier General:
  • 3,614 Answers
Initially try to unplug the unit and plug it again, while holding/pressing the eject button on the player.
if the above procedure has no success, if your familiar with the device the only way to correct it is to open the unit cover, and remove any stuck cd, object inside.,
Thanks
Posted on Jan 23, 2009
  • Bose Master
  • 19,396 Answers
If there is a disk inside, you need to press repeatedly the eject button on the unit, while you restart it at the same time.
Do this a couple of times.
If that does not work, or there is no disk iside, the unit must be taken apart , to access the mechanics and see what is locking them.
    Sergeant:
  • 221 Answers
The assembly is faulty .
tep1bose 321 cd/dvd tray stuck closed - 10006485b_thumb.jpgThe small hole is where the paper clip can be inserted.If the drive will not eject your disc u may need to do it manually.
Take the paper clip and bend one corner so it is straight. This becomes a poking device that can be inserted in the small round hole in the front of the drive. This hole is known as the emergency eject. Step2Slide the straightened portion of the paper clip into the ejector hole on the drive and push gently as you push in the drive tray should pop out. When the drive tray extends outward, gently pull it out and remove the disc. Step3The tray can be closed by gently pushing the tray back into the drive or if the drive has power to it you can press the open close button.
    Sergeant:
    Champion:
  • 435 Answers
Slightly press it and try to eject. If not, open the cover and do it manually.
    Sergeant:
  • 378 Answers
How to open a door of a dvd drive from a pc
There is a mechanical eject hole on the optical drive. Simply insert the tip of a
pen or paperclip into the hole and push to eject the tray. (If your computer's
optical drive is a slot-load model, it will not have an eject hole.)
Bose 321 cd/dvd tray stuck closed. Will not open.
Hello
Check its loading belt for borken. you have to open this deivce. an experienced service technician only can open Bose sets. So get this set repaired by any one well experienced with servicing Bose systems. OK.
Dec 28, 2011 | Bose (321GS) System
My BOSE 321 GSX, was working just fine. I was listening to a CD and started storing it, then someone else tried to stop it, and pushed the on/off, source and eject buttons at the same time. Since then it...
you can open it up and see if you have broken the ac/dc converter. disc tray could have jammed it up. if you dont know much about them then try calling customer support. ^^
Jun 14, 2009 | Bose 3 2 1 GSX System
When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
CD is stuck in my bose lifestyle system, the message displays as "opening" but does not open
Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
Jan 24, 2009 | Audio Players & Recorders
Stuck dvd in the bose 321
Try unplugging the Bose system, then plug back in and press the eject button. This works for me.
Jan 06, 2009 | Bose (321GS) System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose 3 2 1 GSX System Logo
686 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
