Question about Casio Atomic-Solar MTG900 Watch
How to replace battery in casio 27353747 - Casio Atomic-Solar MTG900 Watch
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
Casio Wave Ceptor 2296 watch battery replacement
if it's a water proof watch or water resistant then yes it might use pressure instead of an O-Ring to seal the watch from letting water inside of it. And if thats the case the watch let water in like a sponge in the current state it is in. If i were you and the watch was that important to me, i would take and send it in. Watch battery's need replacing what every 5-8 years? Over that amount of time the price really isn't too steep.
Feb 02, 2008 | Watches
Casio prt 41
If you have that kind of problem with your Casio Watch, there are 2 possible problems here:
-Battery is leak
-They did not reset the watch properly if the battery was replaced.
Best you can do is take it to an official Casio dealer, they will handle your Casio watch properly.
You can find any spare you need for your Casio in our website. At TicTacArea.com we are official Casio dealers and we will be glad to help you with this and any other problem you may find related to your Casio Watch. Casio Watches Casio Multi Task Gear Watches
Apr 10, 2014 | Casio Watches
Reset casio databank 150
remove battery and wait about two minuteslook http://www.pmwf.com/Watches/Casio/FirstMemoryProtectReset.htmand for other casio watches
Mar 05, 2012 | Casio 150 Memory Metal Band Databank Watch...
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How do I replace the watch battery for Casio DW-6900?
    mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
    Aug 27, 2010 | Watches
    How do I replace the lithium battery in a Casio Privia PX-100?
    mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
    Jun 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    How do I reset my Casio PRG-40 following battery replacement?
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
    Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
    CASIO SPF40 battery replacement
    "AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
    http://www.geocities.com/watch_crazy/battery/battery.htm
    Feb 24, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Casio Atomic-Solar MTG900 Watch Logo
    18 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
