Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Reply: What wireless card does your macbook have?
I am not sure what it is but I think it is an Airport Extreme Wireless N networking
  • jbreese May 11, 2010
    It depends on when you bought it. If you purchased it when they first came out then its a G card, which Apple released a patch file to upgrade it to N. The patch cost 1.99
    If you purchased it recently its an N airport card. Are you having an issue?
  • JDTec
    JDTec May 11, 2010
    Airpot wireless is the most common on Macs. What model is it?
  • 160 Answers
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x168C, 0x86)
Wireless Card Locale: USA
Wireless Card Firmware Version: 1.4.8.0
this info can be found in apple/about this mac/more info/system profile/airport card
Posted on Feb 18, 2009
My d-link DAP-1320 connects to my wireless airport extreme but not internet
REINSTALL THE DRIVERS AND SOFTWARE FOR DLINK. TRY A DIFFERENT TYPE OF USB WLAN.
Mar 14, 2014 | D-Link DAP-1320 Wireless Range Extender
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
Aug 29, 2010 | Apple iMac Z0CY Desktop
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
I have a macbook and a pc with a cable modem and an airport extreme. I want to hook them both up so I can use the internet at the same time on the pc and the macbook. How do I do this or hook it up?
Not sure what you have tried yet, so I'll suggest the first thing to try ...
The cable modem will have an ethernet jack on it for "LAN" - you will need an ethernet cable ... plug the cable into this jack .. and the other end of the cable into the airport extreme .. and then power up the airport extreme .. if the airport extreme is new, it will set itself up automatically .. if not new, it might still set itself up automatically - look for a green light on the extreme ... if you have a green light you should be in good shape
Of course your computers have to be in range, say within about 100 feet of the extreme to pick up its wireless signal.
In the MacBook, make sure Airport is turned on - in System Preferences under Network.
Your MacBook should figure things out all by itself and you should be able to connect to the Internet.
On the PC, you'll need a wireless card if you don't already have one ...
You should be able to use the internet simultaneously and each computer should be able to share files if you want to try that (file sharing is turned off by default on the Mac, not sure about the PC)
For AA speaker tapes and PA system help with feedback and echo, see my blog at rexark.com
Dec 19, 2009 | Apple AirPort Extreme Router
I have installed an Airport Extreme wireless system for my home. It works fine on an old pc hard wired and wireless on my macbook pro and my windows xp64 system. It can't find an IP address from my Dell...
You need to make sure the wireless card of the Dell is set to the same settings of the Airport. Also, try to ping the Dell under the ipconfig command. If you still have no connection, then you have a problem with the wireless card.
Jul 10, 2009 | Computers & Internet
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Where can i download the AirPort Extreme wireless networking
Dear,
Kindly find the AirPort Extreme driver at this location.
Regards,
Have a good day.
W.
Mar 19, 2009 | Apple AirPort Extreme (AIRPORTEXTREME)...
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
Apr 14, 2008 | Apple iMac G5 Desktop
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
1,504 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
