Question about Motorola Mobility X205 Headset
I need driver for gaming headset x205
Any ideas
I recently purchased a new headset Called an X205 EA Sports USB Motorola Gaming Headset and I wanted to use it for my Playstation 3 and works fine for hearing but it won't transmit my voice at all it won't...
Maybe this helps:
USB Headsets
  • Through the USB ports on the front of the PS3 system, you may utilize a USB certified headset. Please note, although a headset is USB certified, it may not be recognized by the PS3 if it requires drivers for installation.
  • Devices that are approved for use with the USB ports of the PS3 system must either be made by SCEA or be USB certified. Typically, a USB certified product will have the official USB logo on the package, manual or on the "belly" label of the product itself.
  • To use a USB headset you will have to select it as the input and output device. To select the headset and make adjustments, go to (Settings) > [Accessory Settings] > [Audio Device Settings] option. Then you can use the headset with compatible PS3 format softwar
Jun 27, 2014 | Radio Communications
I have a Motorola X205 gaming headset. And the wire from the head set to the controller broke I cant find a replacement part. Can you tell me what to order or get one from?
You would have to solder the wire together and get some electrical tape to put over it, but overall if it was not too expensive I would just buy another, but soldering is an option.
Apr 28, 2009 | Motorola Mobility X205 Headset
I need the drivers to down grade from vista to win xp on a satellite x205-s9359
Here is a link to a lot of them
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1757703&rpn=PSPB9U&modelFilter=X205-S9359&selCategory=3&selFamily=1073768663&selModel=1757703%7CPSPB9U
but there is no display driver or wireless driver included. Depending on which devices ( of these two ) you have, you will have to try to go to that mfgs web site to see if they have the XP drivers.
Good luck with this, as it can be a trying experience.
Mar 18, 2009 | Toshiba Satellite X205-S9359 Notebook
Need drivers for x205
I will give you a easiest way for finding the drivers that you need foryour hardware.Just download the software named driver magician.Installit and it will search for the drivers that is not installed for thehardware you have through internet and will download it for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
Jan 23, 2009 | Motorola Mobility X205 Headset
X205-S7348 HELP
try updating the video card drivers on toshibas website. there are some games that you will not be able to use a high setting on. this system is a good unit but if you wanted better gaming performance would have recommended the x205-sli5 or sli6. the sli systems have two video cards that work together to give you the best possible performance.
Jun 07, 2008 | Toshiba Satellite X205 Notebook
Cannot pair wireless headset to pc
Hi i have got bluetooth devices Headsets on my pc how do i get the sound in to them from my pc
pbjenks@blueyonder.co.uk
Apr 09, 2008 | Motorola Mobility X205 Headset
Motorola Mobility X205 Headset Logo
168 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
