Question about Whirlpool LER8648P Electric Dryer
Whirlpool LER8648PW1 turns but no heat
I have already replaced thermal switch(s)? on duct housing (mistakenly measured with one wire still connected!). Did not solve problem so now I have spare parts :). I have now isolated problem to voltage issue at the heating element. I have proper voltage to dryer (240v; 120v; 120v) but at the element only have 120v on wire (white/red I think) that travels up wiring harness but 0v on red wire leading to motor area at bottom of the machine. To reduce me from buying more parts that are not the problem I have tried to locate a wiring schematic and have not been successful thus far. Any help locating this would be appreciated. Any assistance with solving this issue would be even more appreciated as I am starting to feel like I woke up in a 'Little house on the prairie' nightmare with all these clothes hanging around the house drying! Thanks, Joe
    President:
  • Whirlpool Master
  • 2,651 Answers
The wiring schenmatic is located inside the console area. but real simple, youll need to check(with wires off) continuity throiugh all of you thermostats, in particular, the one at eh botom and top of the heater pan, as well as continuity throughthe heater itself
Posted on Jan 23, 2009
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
Kenmore 70 series electric dryer wont heat up.I have already replaced the heater and the temp switch
You may want to check the Thermal cutt-off at the side top of the heat duct, or the Thermal fuse attatched to blower housing. There is also a High-Limit at the bottom of the heat duct.
Apr 12, 2011 | Kenmore Dryers
My 110.96584120 won't start. Is it the motor?
It is not necessarily the motor but the thermal fuse located on the blower housing. This thermal fuse is wired in series with the motor and if it is blown, power to the motor is terminated and no dryer function works. Disconnect power then Pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 29, 2011 | Kenmore Dryers
Dryer will not come on or anything.
Hello there:
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing.
Jul 06, 2010 | Maytag SDE3606A Electric Dryer
Dryer on but no heat or rotation
The dryer will not run if the door switch is damaged or, the thermal fuse is blown as well. check both areas for faults. replace the thermal fuse is found to be blown. it will show no continuity if measured with a meter if this is the case.
It is usually located on the blower housing or vent duct inside the dryer.
Jul 20, 2009 | Dryers
The dryer won't start
Door switch
Thermal fuse
Wiring
May 31, 2009 | Dryers
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
Door switch
Thermal fuse
Wiring
Apr 01, 2009 | Kenmore 63942 Dryer
Maytag dryer home-electric, wont start
i f your dryer doesn't work at all, it could be because of problems with:
Door switch
Thermal fuse
Wiring
Mar 06, 2009 | Samsung Dryers
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Door switch
Thermal fuse
Wiring
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Dryer wont start.
Door switch
Thermal fuse
Wiring
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Thank you,
Dave E. (Illeagle)
Apr 15, 2008 | Roper REX3614KW Electric Dryer
Whirlpool LER8648P Electric Dryer Logo
544 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
