Question about Home Security
Genie pro screw drive motor hums - Home Security
2 Suggested Answers
SOURCE: Can't remove the top to get to the motor
2 of the 4 fasteners on my Genie were TORX head screws with the little round 'blocking post' in the opening.
I acquired a set of TORX drivers which have a hollow center to accomodate these particular fasteners. (Maybe the tools came from Harbour Freight)
The REAL problem is that a new motor seems to cost 2 or 3 times the price of a new wet/dry vac.
Good luck
Posted on Dec 31, 2010
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
How do I program a "clicker" brand remote for a genie pro 83 garage door opener?
generally you find the program button on the motor housing, press it once and it should start blinking, then press the remote button, and then press the remote button again and see if it works.
Jul 10, 2015 | Genie Pro Building Materials
Can I use tje existing screw/rail of the 1/2HP Genie CM86001C and replace the old head with the new PowerMax 1500 head or does the new PowerMax 1500 require a new screw/rail?
No rail wont fit quite right. I would consider a liftmaster/craftsman/chaimberlain with yellow antenna wire. The liftmaster models are 8355 or 8550. Not sure how those model #'s translate to the craftsmans and chaimberlains. These units use 3 frequencies which are chosen automatically by opener radio. This gives you the best option to avoid interference. Genie typalically uses 2, but their fixed, so its a crapshoot to avoid interference. Do not confuse these frequencies with the rolling code feature which is a static frequency with only the "channels" changing.
Mar 28, 2015 | Genie Garage Door. PowerMax 1500 1 HPc DC...
My Genie CM8600 garage door opener runs, but prematurely goes back up. No obstructions, settings adjusted on power head-- maxed out. It seems like it reacts to resistance. Is the motor just old? I r
Try manually disconnecting the door and run the mechisim up and down using the opener..see if it runs the entire length up and down... If it does it most likey the door or its mechinism is binding...good luck
Dec 06, 2014 | Genie Pro Screw Drive Garage Door Opener...
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
Own late model 12hp Genie screw drive garage door opener and want to know where to locate the Learn Code Button.
It will be on the outer surface of the motor head, or under the light cover. It will be the only one you can press. Some older units have dip switches which look like a row of toggle switches. If so there will be no learn button. Thanks BB
Oct 22, 2010 | Genie Company Genie 33944A Excelerator and...
We just installed a genie opener with an extension kit for an 8 foot door. The door will only close (using the opener) up to the point of the extension screw drive connection with the last rail/screw...
This has happened to me a couple of times. You will need to return the product as defective and get a new one. This is what genie has told me to do. The problem is that the screw pattern is off just a little and the trolley locks up in a bind as it comes across the piece. Thanks BB
Jul 29, 2010 | Genie GSX8 Screw Drive Rail Extension Kit
Good luck
May 24, 2009 | Genie Company Vacuums
Home Security Logo
67 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
