Question about Harman Kardon AVR 120 Receiver
How can I hook up an analog turntable to AVR 120
I am getting back into vinyl and would like to hok up my turntable to my HK AVR 120. no inputs for phono - what can I use? none of them seem to work but I am not 100% my turntable works
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
SOURCE: no sound?
yeah actually the prein jumpers were the problem...they had worn out....one of those "could have kicked myself" things....thanks for the help tho
Posted on Feb 21, 2008
  • 4 Answers
SOURCE: Humming sound(speakers)when HK AVR 3550 is powered up?
yea try use in a monster power strip it clears al of that up it is picking up noise from all the wires
Posted on Apr 02, 2009
  • 382 Answers
SOURCE: HK avr-25 - everything seems to work except sound
Check the speaker 1/2 buttons that turn the speakers on and off, they have a habit of getting corroded. Click them in and out about 20 times each.
Play with the balance knob, run it side to side about 20 times. Turn the unit off and do the same with the volume knob.
Ensure mute is off.
Check that the tape monitor is off.
Check that you are on the correct input.
I cannot remember if the MK2 had pre-out to main-in bridges on the back, if it does make sure they are pluged in all the way.
Let me know if this helps,
Cheers,
Kevin
Posted on Feb 03, 2010
Testimonial: "Some good things to try. I will later today. Thanks"
SOURCE: My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Posted on Apr 10, 2010
How can I connect a Thorens 145 turntable to it?
Your Harman Kardon AVR 85 doesn't have "phono" inputs. That means that you can not connect a turntable to it directly. You will need a "phono preamp" to amplify the very tiny signal from the phono cart enough for the HK receiver to play it. Something like this:
PYLE PRO PP444 Ultra Compact Phono Turntable Preamp
will do it. There are certainly better ones, like:
Amazon com TCC TC 750 BLACK Audiophile Phono Preamp Pre amp Preamplifier...
Feb 23, 2016 | Harman Kardon AVR 85
My receiver works fine when I plug my iPod into it, but when I plug my turntable in I can't get any sound. Any idea?
The phono cartridge on your turntable puts out a much lower level signal than your iPod. Back when turntables were popular, all receivers had a special phono input to take care of that. Your modern HK receiver does not have a phono input, so you need to get an external phono preamp. Plug the turntable outputs into the phono preamp inputs, then plug the phono preamp outputs into one of the audio inputs on the HK, like where you connected the iPod.
Oct 08, 2013 | Harman Kardon AVR 745 Receiver
I have a Kenwood VR-507 trying to hook up Teac EQA-120 Home Equalizer
As with any stereo analog device, processor or tape deck - Outs go to Ins. But any typical AVR will only be able to use it for analog stereo sources. Once a Tape Loop is engaged all digital inputs are disabled though you CAN still use DSP effects on the analog sources.
Sep 11, 2011 | Teac EQA-120 Home Equalizer
I just bought an Harmonkardon AVR 354 7.1 receiver and am having trouble hooking up the HK DVD 48, the Sony Bravia and the Hd cable box. The tv has four HDMI hook ups and the dvd has 1 and the cable has...
http://www.retrevo.com/support/Harman-Kardon-AVR-354-Receivers-manual/id/19547ci973/t/2/
I see only two potential HDMI sources - Cable and DVD. You have three possible inputs to choose from. BTW: Composite Video is also HD in an analog form. Keep it in mind for the future.
You have an HDMI Out for feeding one input on the TV.
Ponder why all the devices have separate (and multiple) high-end audio and high-def video paths. This is what I do...
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room especially if it only passes through a device on the way to another one with no improvement. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption.
Sep 09, 2011 | Audio Players & Recorders
How do I hook up a turntable to a Harmon Kardon AVR receiver? Can't find correct inputs. Thanks
A 'generic' turntable and a 'generic' HK AVR?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Or your TT may have i
Jun 16, 2011 | Harman Kardon AVR 65 Receiver
Question on Bose 3-2-1
hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose)  to heard and listen to your old vinyl.. mk2 batallion.....
Feb 24, 2009 | Bose 3·2·1 II System
HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
Dec 25, 2008 | Harman Kardon AVR 120 Receiver
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Pierre
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Nov 26, 2008 | Denon AVR-1603 Receiver
Hook-up
http://wzpo.ask.com/r?t=p&d=cap&s=fwpus&c=a&l=zr&o=sb&sv=0a300516&ip=29b28a2c&id=9C081BFE154A69ACB38D55982924AB2E&q=manual+of+harman+kardon+avr+120&p=1&qs=121&ac=29&g=33c8zcdlUuHiRw&en=te&io=0&ep=&eo=&b=alg&bc=&br=&tp=d&ec=10&pt=Harman%20Kardon%20AVR%20120%20Receiver%20Owner's%20Manual&ex=tsrc%3Dtxtx&url=&u=http://www.manualnguide.com/download/manual-guide/harman-kardon-avr-120-receiver-owners-manual.html. have a look in manual above from page 9.
Sep 06, 2008 | Harman Kardon AVR 120 Receiver
Harman Kardon AVR 120 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
