Question about Sega Genesis Console
I need hook-up instructions for my 16 Bit Sega Genesis system con
I would like to receive instructions for my sega Genesis Sys. Console.... Need know how to connect to Tv, Dish Sattlite Box, VCR, and sega console. Can you send instructions that I can print out on printer?
  • Anonymous Apr 25, 2009
    same thing
  • 8,197 Answers
I have a sega genesis 16-bit i have sound but no video. The av cable fits tight and none of the pins are loose.
do u have it on correct channel,,3 or 4,,also there may be a switch on av box also,,must be the same,,,if still nothing after checking all connections on sega and av,, get another,,also check see if a channel swithc on sega as awell
Aug 04, 2012 | Sega Genesis 2 Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
We just purchased a Sega Genesis 16 bit sysyem...Model 1601. We do not have hook-up instructions. Would you be able to help us?
Wow, that is a pretty vintage little game system you got there, but sure I can do the best I can blindfolded.
you should have gotten a A/V cable that ether has a RED/WHITE/YELLOW or a RF Co axe end.
If you got a A/V what you do is hook that to you TV where it says input.
If you got a RF coax you would need to hook that into the round cylinder input with a hole in the middle.
If its AV the tv would need to be put on input. If its the other the tv would need to be on channel 3.
Whatever the case may be please update me if you have any other questions.
Kind regards
Rulds2008
Jun 15, 2011 | Sega Genesis Console
How to hook sega genesis up to a flat screen tv
You need to hook up the cable coming in from the outside to one end of the Sega RF cable and hook the male end of the RF connector from the Sega into the cable input on the TV.On the back of the game console there is a channel selector switch.It is either CH3 or CH4 which is what your TV needs to be on when you turn on the console.If one looks bad try switching the channel selector on Sega and on the TV.
Good luck and game on!
Jun 09, 2010 | Sega Genesis Console
How do i install a sega genesis 16 bit to my tv and what kind of cords do i need
Sega genesis has a proprietary plug which goes to a standard RCA Style cable. They go for about $9 on eBay.
Or you can get one from Amazon here.
Apr 29, 2010 | Video Game Consoles & Games
Help connecting a Sega Genesis 16bit system!
What you will need to do with the RF cable is to take your incoming cable thast goes to your TV and screw it into one side of the RF box. Then the adjacent short cable wire that is on the other side needs to be screwed into your TV. The long end of the cord plugs into the back of the sgea unit. Good luck! Any other questions, feel free to ask.
Nov 07, 2009 | Sega Genesis Console
Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Sep 23, 2009 | Sega Genesis Console
I have a Sega Genesis MK-1631 but I need the cords
gen1.jpgthey are calledxeye_and_32x_03.jpg Genesis A/V Cable for Original Genesis System
Dec 28, 2008 | Sega Genesis Console
Sega mega drive - how do I plug it into tv?
Ok, a few basics to hooking up your console. Firstly you should have two cords a power cord that plugs into the wall and into the back of the console. Another cord should also plug into the back of the console and the other end should be plugged into the back of the television into the slot called in. However if this plug is already taken by a vcr you can hook the cord from the sega up to the vcr in port. After it's all plugged in and the console and tv are on and it's directly hooked up to the tv then change the tv channel to 3 or 4 and you should have something on one of those channels. However if you hooked it up through the vcr then you have to go to the channel that normal has your vcr then change the channel on your vcr to 3 or 4. I think this is all you need to know good luck.
Nov 01, 2007 | Sega Genesis Console
Sega Genesis Console Logo
2,397 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
