Question about RCA 27V520T 27" TV
The set is dead 0 amps
RCA Model PS27112 TV. I have 115V on the PC board and an ammeter shows ZERO amps so I am not getting power to the instant on circuit. I have tried to find a print on line with no results. Can you help?
  • 767 Answers
The power stop at the Hoz out tran
check to see if its short, with the power off .
also check all fuses. and be carful
Posted on Jun 30, 2009
Hello...Have RCA L40FHD41YX9 ,serial number J203C40GV. Watching t.v., picture and sound go. Unplug, then replug...blue light in front, but still no picture or sound. Please advise
Fred, Unplug for a couple hours then try, if does not reset, board,capacitors or power supply gone bad.
Check the attached links for TV's problem.,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fix Your TV Instantly
how to fix 42 RCA flat screen
RCA 276046 Power Supply Unit PSU Boards Replacement Guide for RCA LCD TV...
http://v6.tvrepairtips.org/anon/supertips?page=1&make=&model=LTV46W1%20HD&problem=
Mar 07, 2016 | RCA Televison & Video
Where is the lamp on an rca d52w15 tv?
That model doesnt have a lamp. They have three CRTs ( Picture Tubes) instaed. You can get the parts for your model at www.tvrepairworld.com. If you have sound but no picture youre needing a deflection board, same item if the set is dead or if the power led flashes three timnes slowly. They all indicate a bad deflection board.
Aug 08, 2011 | RCA D52W19 52" Rear Projection Television
I have a 52 RCA flat screen that the sound works but the pic doesn't. I can hear a clicking sound and then the power button light starts flashing
This RCA projection tv model have known to have many parts of capacitors components are dying and dead on the tv power supply board.That the board section where the tv power a/c cord plug into it.U have all the tools and can do bsaic soldering work too?Yes,try website like Tvrepairworld.com to buy the capacitors compponents set they put together and replaced all these capacitors parts on the tv power supply board section,will solved this problems.
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
Tv went dead while in use. 2 months old. Can not find my reciept for warrenty... Coby LCD 40" flatpanel. Fuse on main power circuit board is fried. 6.3 amp/250. Tried a jumper with a 7 amp fuse and it...
It is clear you have a dead short in the power supply board, and chances are the board will have to be replaced, most technician are forced to replace the boards when it comes to LCD sets. There is nothing more you can do unless to have test equipment to help. If you can't find the receipt but paid by credit card your statement will be proof enough and that will give you the coverage you need.
Feb 15, 2011 | Coby TFDVD1550 15 in. TV/DVD Combo
TV showing picture but no sound
Could be the cable box is bad,u should check all other tvs in the house are find,if it have sound? Yes,tries unplug the tv and the cable box about an hour.Replug both back in.Let the cable box upgrade it software.The tv it now resetting back to it factory setting.Go into the tv Menu,go to AUDIO setting,go down to reset the AUDIO setting back to factory setting.The tv should have sound now.Not,than the Tuner board is dead,that the board take in the tv broscasting cable signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 02, 2010 | Samsung LN52A850 52 in. LCD HDTV
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
May 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound went out?
Unplug,replug the tv about an hour later.Let the tv to reset it self back to factory setting.Go in ur tv menu go to AUDIO setting.Go down to reset.Now ur tv should have sound back.No,sound after the reset.Than ur tv Tuner board is dead,require changing the Tuner board.
May 27, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a rca 52inch hd52w56 power light on front of set is solid,then flashes ten times,then solid again for a minute. repeats. tv will not turn off or on. ???? screen not on,no picture,no sound,nothing??
DM power board have some dead capacitors.Some capacitors bulge up,best indicatoin it dead,some u must used a multimeter to test.U know how to use a soldering iron and solder?Change all the DM power board capacitors,should get power back to ur tv.Try website Tv repair World.com maybe still selling this refurbish DM power board.
Mar 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv shut down and wont power back up, but circuits stay powered up
Check to see that the fuse is good. If so, test power supply. It is common for these to go out..
Sep 13, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
