Question about Sony CDP-CX230 CD Player
CDs jammed, some broke. Now loading arm seems misaligned.
Loading arm sometimes does not grab a cd. Disc falls back onto carousel, or worse, misloads in reader, jamming against carousel or just hanging. Tried to identify common issue, but seemed quite random. Any ideas?
ginko
  • 19396 Answers
SOURCE: Sony PMC-R35L "no disc" message
That is usually because of dirty or defetive lens.
Try first using a len cleaner , like the ones here.
If this does not work it will be necessary to take apart the unit and accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
Posted on Dec 16, 2008
  • 5 Answers
SOURCE: Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Posted on Feb 10, 2009
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Posted on Mar 07, 2009
  • 15 Answers
SOURCE: jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
Posted on May 01, 2009
SOURCE: cdp cx300 parts schmatic
I'm having the same issue. Can you tell me where I can find the part you are talking about?
Posted on Dec 14, 2009
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Sony CDP -CX200 Arm comes forward to pick up cd but goes back empty. It will not load the disc to play.
Is the second part of the arm clamping the cd? If not then the arm is probably broken and needs to be replaced.
Dec 28, 2012 | Sony CDP-CX70ES CD Player
My Kenwood DP-j1070 100 changer is finding cds but not playing anything - there seems to be a spring loose on the loading arm - and not quite sure how to repair - thinking this may be the source of the...
The piece of plastic that held the spring in place probably broke off like mine did. I repaired it by drilling a small hole under the bottom of the slot in the arm and connected it with a piece of solid wire.
Dec 25, 2010 | Kenwood DP-J1070 100-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Jammed tray
May 01, 2009 | Sony CDP-C265 CD Player
Hi there.
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT 100CD
I asked a Wurlitzer engineer about this problem and he simply said, "Bend it a bit."
Sounds horrible but there is no genuine adjustment. But before doing that, try moving the carousel lock latch (at the 5 oclock position). This is what locks the carousel and determines its position when the correct CD number is reached. If you could ****** or advance it a little it might work.
Dave
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
CDs will not load
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Nov 08, 2007 | Alpine CHM-S630 6-Disc CD Changer
Sony CDP-CX230 CD Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
