Sound still appear at speaker even when headphone was installed
My laptop speaker still have sound even when i'm installed the new headphone.
how can i disable the sound at laptop speaker. because there are 2 sounds appear and i just want the headphone enable only
  • 177 Answers
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Posted on Jan 23, 2009
How can I fix my aspire 5349-2804 headphone port?
Power output on a headphone socket is not great - depends on the headphone and speaker resistance - have you tried a cheap pair of in ear headphones to see if it is the headphone socket.
Headphone socket does sometimes break like the power socket its one of the most common problems on a laptop.
If so its not difficult to find a new headphone socket or even re-solder the old one - it may be a dry joint!
Are you getting sound through the laptop speakers for a start.
The headphone socket should interrupt the main speakers automatically so there is no setting in sounds and devices in windows that would cause your problem.
May 12, 2014 | Acer Aspire 9300-5349 Notebook
My sony vaio has no sound coming from the speakers i have tried to uninstall and install the drivers but nothing is working the sound appears to be on as media player has no problem playing anything. my...
attempt to connect external speakers or headphones. if thet work, your internal speakers are the problem and needs replacing. you may also at least check the sound properties and under playback section, make sure the correct playback device is selected. Normally, it should be the speaker/headphone audio device unless you use digital playvack device.
Dec 31, 2010 | Audio Players & Recorders
I have Dell Latitude D500 No sound Appear even when I installed SIGMATEL STAC 9750AC97 I dont know what is the problem lease help me
first of all check if you have sound in headphones if not go to start->accessories->system tools->system recovery and here chose day that you know that your sound was working. If it will not fix it try to reinstall sound drivers, and last hope is in reinstalling operating system. If you have sound in speakers its fault of your laptop speakers and you need to change them.
Jan 01, 2010 | Dell Latitude D500 Notebook
Disabled Satellite A215 internal speakers and now can't enable!
you may want to try and reinstall the driver from the manufacturers website. I had to do that with a brand new notebook as the speakers didn't work when first turned on. I'll see if I can locate a link and post again if I find it.
Mar 31, 2009 | Toshiba Satellite A215-S7407 Notebook
Headphones and laptop speakers work at the same time
I have compaq presario c773tu laptop .I can not find sound driver on internet.
Jul 03, 2008 | Compaq Presario 700 470024-192 Notebook
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
No sound on laptop
there is no sound in my laptop
Apr 25, 2008 | Edirol UA-4FX External Sound System
Sound problem with Aspire 5570
I had the same problem with my Acer 5570 and I just fixed it. What I did is to go to Control Panel > Sounds And Audio Devices >Hardware >On Devices click on Reatek High Definition Audio >Click Properties > On Devise Usage choose the option Do not use this devise (disable) > click OK >then plug in your headphones, click on Realtek High Definition Audio properties again and click on Enable Devise **with the headphones plugged in**. It worked for me.
Sep 03, 2007 | Acer Aspire 5100-5480 Notebook
422 people viewed this question
 Grubhead
Grubhead
