Question about Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio
Scematic need F235 Resister crossrefernce and or value and location on circuit board.Glass encase 4mm redish orange, black end.
  • KENNETH NANYS Jul 07, 2007
    Cannot find on internet
  • KENNETH NANYS Aug 02, 2007
    Thanks, do you think any electronics component store can ID it with out the scematic? Jake
  • 883 Answers
Your description of "Glass encase 4mm reddish orange, black end." leads me to deduct that this is a diode. The black end denotes the cathode. For more help, post back.
Posted on Jul 08, 2007
  • Marty marty Aug 02, 2007
    look at it under a magnifying glass and look for any printed numbers.
  • Trevor Durstine
    Trevor Durstine Dec 09, 2013
    when i turn it on it gets brighter but when it is off it get dimmer
Maytag MDB7100AWB dishwasher board burnt resister
first of all they wont give you any specs on circuit boards for most appliances,they just want you to replace the board besides that,if a resistor burnt its because there was a heavy current draw on another component that is supplied by this resistor and you would need to locate this defective part such as a motor/solenoid/heater or the new resistor will end up in the same manner,the 2 oozing parts are probably capacitors leaking their die-electric compound from heat and age so they are in need of replacement too,you might go online and ask somebody with a board like yours for the part values,but still you need to find the main problem for the problem on the board first
Aug 12, 2012 | Maytag MDB7100AWB Dishwasher
Circuit board defective
If you have warranty then go to the shop from you have bought it.
Jun 20, 2012 | Computers & Internet
My rca projection tv will not turn on
hello, do you mean no power at all if have you check the glass fuse inside the tv in the power supply if it's black in colour then it's blown make sure you use the same rated fuse the value will be on the end of the fuse or on the fuse holder on the circuit board
regards
shaun
Nov 21, 2010 | RCA D52W19 52" Rear Projection Television
My tv is 3D.....I purchased the repair kit, but it did not come w/the right resister. I went to radio shack and they can't read the # on the olld resister, so I need to know what number should it say on...
What is the location number of resistor on the board? I assume you are replacing the STK ICs
is one resistor in that circuit? It has to be a low ohm resistor What are the Band Colors on resistor?
Example brown,red,black 1.2 ohms
Nov 12, 2010 | JVC AV-48WP30 48" Rear Projection...
I have a red orange and black wire i need to know what the orange wire is
hello, in my Cobra 18 WX ST II the orange wire goes to "mic2" on the circuit board the other end runs to pin # 2 on the mic jack
May 21, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
Power on but no click sound. found some transistors and resistors burn in a small board located at down side of the amp, need scematic circuit diagram to repair it. Please send.
If you have burnt the transistors that are located on the circuit board, then you wont be able to repair it I dont think because in the circuit board there are probibly mulitple layers of electrical wires the are extremely small and fine that would make it impossible to connect the transistor to the right layer. Try contacting the manufacturer though
Oct 08, 2009 | Audio Players & Recorders
No power to my PSW110
The fuse may be located in several spots:
- fuse inside the three prong power plug connector on the sub (if there is one) - see if it has a fuse compartment built in - it should slide out kind of like a small drawer - sometimes it has also a separate place for a spare plug in there - the fuses used are of glass type.
- fuse mounted into a fuse holder soldered onto the circuit board - glass type fuse
- fuse soldered directly onto the circuit board - sometimes the type used is glass (it may have a heatshrink tube around it so it doesn't look like a fuse at a first glance, also there are other types of fuses that can be soldered directly onto the board - these are in the form of a small vertical cylinder, usually of a dark reddish colour with white / yellow print on the top - they look somewhat alike to small electrolytic capacitors, but are encased in dark red plastic with the pins located directly underneath the fuse.
Hope you can find it...
regards
3rq8 (Triarcuate)
Sep 10, 2009 | Polk Audio PSW110 Subwoofer
Resister burnt
Guest and Lesfix. RU83 located on the DRC8335 VCR PCB is a 51ohm 1/4 watt 5% tolerence resistor, color coded green-brown-black-gold. As to zener diode DU83, I haven't been able to determine it's value yet but am working on the problem.
Be aware when either or both these components fry, this indicates you need to replace the following two overheating capacitors on the power-supply board, which were directly resonsibile for knocking them out:
• C216 1000µf 16 volt (upgrade to 35 volts)
• C218 1000µf 10 volt (upgrade to 35 volts)
Could you email me regarding this problem when you have time. Mention Fixya and DU83 in the subject line so I realize it's from you. Thanks. mikeadams110@yahoo.com
Oct 02, 2008 | RCA DRC8335
Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Logo
88 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
