Question about Maytag Neptune MAH5500B Front Load Washer
I have a clicking sound on my maytag neptune washer. it clicks through the whole cycle, is that normal? it sounds like clicking and then spinning, like wheel of fortune show
  • 90 Answers
I would check the agitator,( the middle part of the washer that turns back and forth, hence agitator) and see if it is snug, by popping off the cap at the top of the agitator with a flat-head screw driver, and then checking to see if the nut is on tight or the four little hooks, that hook onto the jagged teeth, around the top of the agitator. I hope that this helps.
Posted on Jan 23, 2009
I have a maytag neptune washer and the spin cycle is really loud is that normal. Kinda like a jet engine but it is complete level we checked?
you have described the noise from a front load washer in the spin cycle to a "T", it definately does sound like a jet engine. if it ain't broke...don't fix it!!
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clicking sound
sounds like it probably has a bed bearing on the tub . pretty expensive most usually replace the washer.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Describe your Maytag Neptune MAH5500B Front.loader...Creaks when washing
Hello saber396
welcome
Here are some facts that may be the sounds!
You said. you noticed lately that I hear a creaking sound when it is in the wash cycle...Is that a motor problem?
Clicking/draining sounds
when washer is started will be
before the washer starts to fill, it will make a series of clicking noises to
check the door lock and do a quick drain.
Could it be a rapid snapping and/or
popping sound from the rear
of the washer during spin.
means that
Water is being extracted through the drain holes in the spinner and is
hitting the outer tub before draining out of the machine.
Let me know if these help any one understand the sounds!
Huuum
Please remember to leave a rating!
Jun 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Clicking noise
center bearing that holds the shaft is bad and lets the shaft move
Mar 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
131 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
