Question about Lexmark C772dn Laser Printer
How to remove the redrive belt on a C772 Lexmark printer
2 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: I have a Lexmark C772
Please click on the link to see instructions on how to go about the procedure.
http://bitly.com/pguMf7
Please call Lexmark Technical Support for additional assistance.
Posted on Jul 12, 2011
Error code 201 lexmark t630
201 is a paer jam message generated by the fuser (hot thing in the back of printer) remove rear door and the redrive unit. ( two screws on back of printer and press in two levers on upper portion of back to remove) either the switch on the left of the fuser is stuck or the switchneeds replacing (assuming it is a false paper jam)
Oct 15, 2013 | Lexmark T630 Laser Printer
Lexmark c772 when printing it make load Laud noise
Please power off the printer. Remove all the toner cartridges. And then put them back in. Make sure you install the toner cartridges properly. After that power on the printer. Try printing again.
Jul 20, 2012 | Lexmark C772dn Laser Printer
How to replace mirror motor assembly lexmark t632 or printhead
I would suggest you contact a certified Lexmark trained technician to replace the printhead or you may contact Lexmark Technical Support.
Oct 12, 2011 | Lexmark T632 Laser Printer
Paper crunched up and jammed i n rear of printer I cant remove it.
If this is constant, it may be caused by the fuser or the redrive assembly. I would suggest you contact Lexmark Technica Support.
Oct 07, 2011 | Lexmark T640 Laser Printer
The paper is jamed in the back and I can't find a way to release it. Lexmark E340
jammed in fuser which is in the back to get to fuser remove rear door remove redrive two screws you will see the fuse be carful output sensor in middle of fuser just pull it gently if it jams again may need a new fuser
Sep 08, 2011 | Lexmark E340 Laser Printer
Lexmark T640 squeaks when it prints. It sounds like it is coming from the fuser area, but I can't be for sure. It seems to happen a lot around here (we have over 100 lexmark printers). Can this be fixed...
That can be caused by several factors(e.g. small paper stuck inside the printer, the roller or the toner cartridge). But here's a link to the Lexmark website to guide you on what to do when having this kind of problem on the Lexmark T640 printer. http://bit.ly/cFLEel. Hope this helps. If all else fails, I suggest you contact Lexmark Technical Support for further assistance.
May 17, 2010 | Lexmark T640 Laser Printer
Jams, no print
Remove the redrive and try to print again. The unit does not need
a redrive installed to print and it's an easy test to perform.
Let me know the results of this and we can continue.
May 22, 2009 | Lexmark T634n Laser Printer
Paper jam back door of Lexmark T640
I went at it with surgical tools and was able to grip and remove the paper by the visible edge
Dec 12, 2008 | Lexmark T640 Laser Printer
Print head replacement lexmark t632
You will have to remove the top cover, both side covers and the rear door and redrive to get to it. Once these covers are removed you will need to remove three screws to release the printhead and disconnect a couple of cables.
I usually have to clip a couple of zip ties and use needle nosed pliers to get the cables out.
It is do-able if you are patient.
Nov 24, 2008 | Lexmark T632 Laser Printer
Lvps
Remove the fuser assembly
Remove the rear cover
Remove the fuser top duct screw and disconnect tab
Remove the top duct
Remove the redrive belt cover duct
Remove fuser left duct
Remove fuser bottom duct
Swing lever and disengage VTB shaft
Remove the fuser drive assembly screws and remove the fuser drive assembly
Disconnect the J33 and J35 cables from the system board
Remove the four LVPS screws from the rear of the printer
Remove the right rear cover screw
Remove the screw from the top of the LVPS and remove the LVPS from the
printer.
Installation notes
When installing the new power supply, set the voltage range switch to the proper power setting for the
geographic area you are in.
Be sure to set the voltage range selector switch (A) on the LVPS to the proper setting.
Aug 25, 2008 | Lexmark C760 Laser Printer
Lexmark C772dn Laser Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
