Question about Motorola Mobility RAZR V3
I cant hear my voice records
When i used my voice recorder and press play i don't hear nothing so i'm asking what is going on here
You will here it if you put your ear up to the phone like you are talking in it
Posted on Jul 10, 2007
I use Samsung C3010. when playing music player, I don't hear any voice. I only hear the instruments. I've tried many airphones but nothing. can it be solved?
How are you obtaining the music that you play on the Samsung C3010? If you're recording the songs yourself, it sounds like you are recording one channel out of phase with the other. This phasing "effect" is how vocal eliminators work. Try playing back music from another source and see if the vocals return.
Aug 14, 2013 | Audio Players & Recorders
Terrible sound when recording music in XQ
Hiya marco1ca...The recording qualities and characteristics of your Digital Voice Recorder is designed and optimally calibrated for Audible (voice) recording. Essentially, recording of sounds with peak levels that exceed a conference room of 20 or so people speaking at moderate levels will completely overun the sensitivity and be over-modulated both during recording, and during playback, as in your experience, producing unrecognizable audio. Although it supports and plays Audio files such as mp3 and WAV with ample quality, while doing so, it is only functioning as a player and not a recorder. If you would like to continue to use your Digital Voice Recorder to record live music, execution of the following Setting changes will provide you with the "best" you can get, albeit, you will still not be pleased with the recording. Our objective is to cancel as much sensitivity of your recorder, both aurally and electronically by removing and retarding all features that promote sensitivity. 1) Remove the Stereo Microphone Unit, and record using the built-in Monoraul Microphone. As you can obviously see, the individual Stereo Microphones are very close together. The method that your DvR uses to achieve stereo separation is by increasing the directional sensitivity of these microphones individually. 2) Change your recording mode from your present setting of ST XQ, to SP by; a)pressing and holding the Menu Button for 2 seconds, or until "Rec Mode" is displayed. b)press OK to enter setup. c)press either + or - until SP is displayed. d)press ok to save your change from ST XQ to SP. "SP" mode does not incur any electronic enhancement or proccessing from your recorder. 3) If applicable, change your Microphone Sensitivity Setting to "DICT" by sliding the Mic Sense Switch located on the left side of your recorder. "DICT" is the lowest sensitivity setting that your recorder can achieve. Finally, if in a secure environment, place your recorder MUCH further away. Sound is the movement of air. You are attempting to record a PERCUSSION band, which truly is the epitome of air movement creating sound. What you have been recording and hearing was not sound, but air which was digitally captured simply because there was not enough time for sound to materialize. If you would like to try an experiment to physically understand the process of sound, have someone stand in front of you and whistle a note, and ask the person to sustain the whistle while approaching you until their lips are as close to, without touching your ear. When that physical point is reached, you won't hear whistling, you will only hear air/wind. The closer you are to the source of the sound the more condensed, and electronic signal proccessing becomes overwhelmed, again, causing overmodulation and distortion. These steps are "all the resources that is available" for your specific recorder. Remember, it is a digital !VOICE! recorder, and there is no voice that is as loud, or that produces the dynamic wavelengths as a band playing. If you would still like more information regarding your Olympus DvR, their Technical Hotline Number is 1-888-553-4448. You can also email them at distec@olympus.com Please update your post on your progress and/or if you have any further questions.....good luck my friend...chris
Aug 19, 2007 | Olympus DS-50 Digital Voice Recorder
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
Jun 20, 2011 | SanDisk Sansa Clip MP3 Player
When i make a call or get an incoming call, i can hear people at the other end speaking. but they cant hear what i say. Please do assist me to solve this issue
It may be a hardware problem. to check it go to voice recorder in your phone in record any sound and save it and play it. if you hear good quality sound (loud and clear) then it is not hardware problem. try formatting your phone it will do for you.
and if you hear bad quality or not at all able to hear any sound of recorded clip then it is hardware problem. you can not fix it by yourself you have to go to mobile repairing shop and ask them to install new mike in your phone. it india it cost around Rs100-150.
hope this was helpful.
THANKS FOR USING FIXYA.
Mar 09, 2011 | Nokia 5200 Cellular Phone
How to change voice message on a v-tech phone model cs6229-3 cannot change voice message-lost instructions manuel.(717)866-9262
Press Menu/Select button while phone is not in use.
Press Menuu/Select button to choose Ans System.
Press arrow up or arrow down to choose Ans System Setup, press Menu/Select button.
Press arrow up or arrow down to choose Announcement, press Menu/Select button.
You will hear the prompt "To play press 2, to record press 7. Press 7.
You will hear the prompt "Record after the tone, press 5 when you are done".
You will hear a tone, record your greeting, speaking toward the microphone. Press 5 to end recording.
Your new greeting will be played back automatically, press 5 to end replay, press 2 to start replay again, or press 7 to record again.
Minimum message length- 2 sec
Maximum message length- 90 sec
Below is a link where you can download a copy of the User manual.
http://safemanuals.com/user-guide-instructions-owner-manual/VTECH/CS6229-3-Pre_E
Dec 12, 2010 | Vtech 5.8GHz Analog Cordless Phone
Cannot hear callers voice during a call but caller hears mine
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
Dec 29, 2009 | Nokia N72 Cellular Phone
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
I have an Olympus WS-311M but cant record after playing back file
Unfortunately that is not possible with this recorder to be able to replay a part of a recording and record over it. If you pause it will just allow you to continue from the point where the device was stopped. You might want to check out the DS-2300 or the DS-2400 model recorders as those devices have the ability to do what you are asking.
Jan 14, 2009 | Olympus WS-311M Digital Voice Recorder
Haw can I record and save? on SANSA of SanDisk
ok so go to menu record and then finish recording itll ask you if you want to
May 29, 2008 | SanDisk Sansa m240 MP3 Player
Voice and Recorder not working!!!! Please DO help!!!! :D
take it technician u need to change its microphone. because it dropped on floor so damage has done with microphone, so take it to technician
Feb 07, 2008 | Sony Ericsson T610
Motorola Mobility RAZR V3 Logo
85 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
