Question about Sony Playstation 3 (PS3) Console
Will not respond to controller
System boots to frist screen but will not respond to controller
  • triolob Jan 23, 2009
    I have the same problem but only sometimes. When I push the PS button on either my controller or remote nothing happens. I have to turn on the system by pushing the power button on the unit and then the system recognizes the remote and controller.
  • 4 Answers
You have to open the battery cover on the controller and press the red button as well as open a small cover/door on the front of the Wii system and also press that red button. This will sync that controller to that specific Wii system. You will have to do this when ever you buy a new controller or try to use any of your controllers on a different console.
Posted on Jan 23, 2009
ACER aspier 5732 will not completely booy up. Get starting windows screen but after that only get black screen and can only see the cursor. Cursor will respond and move acroos the screen when touching...
There are a couple of quick fixes you can do.
First, boot into Safe Mode (Repeatedly tap the F8 key while the system is booting, before the windows logo appears) A Menu will pop up, press Boot Into Safe Mode. From there you can try a System Restore to a known good date.
System Restore - Click Start -> Control Panel -> On the top right, type "System Restore" without the quotes. Click on "Restore system files and settings from a restore point". You can choose the recommended restore or a specific date.
The other option is to boot into "Last Known Good Configuration". To do this, use the F8 trick again while booting, but instead of Safe Mode choose "Last Known Good Configuration".
Please note that either of these run a risk of some data being lost from the time the restore point was made. You "shouldn't" lose anything but just want to make you aware.
Jun 24, 2011 | Acer Computers & Internet
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
Boots up but no display, black screen
Hi there,Thats a problem with the Operating system..
Perhaps Tap F12 at startup and see if boot--menu responds,if so,select boot from HDD,Please Rate Max
Dec 30, 2010 | ASUS G73JW-XA1 17.3-Inch Gaming Laptop -...
Bought a used computer without a mouse.Installed
regarding your mouse issue frist of all what windows your using if u using win 98 or 2000 and your mouse is USB then u have to insatall usb drivers for that windows Xp then it will conact driectly to the Harware it wnot ask for divers
thne chack your mousr will work if not then you have problem with you windows just ub-date your windows
May 01, 2010 | Televison & Video
When my computer starts up after the windows logo loading screen the screen turns black and then my keyboard and mouse stop responding and the screen stays black thats it
Press F8 key after post boot screen and before windows booting, dos screen will come from there select safe mede booting, computer will boot in safe mode
1) Click On start
2) Go to All programs
3) Go to Accessories
4) Go to System Tools
5) Select system restore
Sytem restore window will come there you will select restore my computer to the earlier time, you will get calender on the screen there you have select any highlighted previous date
After restart your computer will be ok.
Apr 01, 2010 | ASUS P4B533-VM Motherboard
Does not boot properly
Try running the diagnostics (Hold the Fn Key and press the power button or boot to the resource CD) See if the hard drive indicates and failure. If HDD fails, replace it. If it passes, then see if you can boot to safe mode (F8 at boot) and see if you can access windows there. If it does boot to safe mode, try MSCONFIG and edit the startup group and see if the system will boot normally in normal mode.
Other possible issues, fan failure causing overheating, or a clogged heat sink (Use compressed air to blow dust out of air intakes and exhaust) Virus and spyware
Sep 26, 2009 | Dell Latitude D810 Notebook
Will not boot. good power, all fans, hdd,video, and initial system beep,power up, but does not show boot screen, almost like its not initializing bios.
Dear Sir
Prees your Key-Bord Delete/f2 key
Advance Option And Frist drive In cd - dvd Rom /
Boot Option And Frist drive In cd - dvd Rom /
Enjoy Not Message
Aug 17, 2009 | Foxconn G9657MA-8KS2H Motherboard
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
How to install windows on my second hand tecra m1
Go to BIOS and have the cdrom as first boot device.
look at screen, you may have to hit a key to start boot from cd.
Let me know how it works out for you.
thanks
Dec 11, 2007 | Toshiba Tecra M1 PC Laptops
No password to enter computer
When the login screen comes up and asks for the username and password.
Username - Administraion
there should be no password for that account.
Once into the system go to the control panel and then to user accounts and change what you desire.
XP home hold F8 untill you get to the boot mode and choose Safe Mode once in to the system go to control panel and user accounts and do the same as above.
If this doesnt work please respond with OS.
Dec 05, 2007 | Acer Aspire 5100 Notebook
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
