Question about Acer Tablets & eReaders
How do i turn on my acer 0682 - Acer Tablets & eReaders
I have got acer iconia one 7 and just turned it on. When i go to connect to wifi by sliding it across at top, nothing happens just says'to see available networks turn wifi on?! its not finding any...
You have to turn on the wi-fi connection on the tablet.
Go to settings and turn on wi-fi.
Then go and look at the connections displayed.
Pick which one you want to log on to and enter the appropriate password.
Then you use the internet.
Mar 06, 2015 | Acer Tablets & eReaders
I just brought my new iPad Mini home and can't seem to get it started. Do I need to plug it in and let it load up before it will work. Where is the cord supposed to go? The top slider must be the on/o
The quickest and easiest way would be to take it back to the store you purchased it from, and ask for some guidance. They must be pretty poor to have sent you home without showing you even the most basic processes relating to your iPad.
If they are unwilling or unable to help you, take it to your nearest Apple store. I'm pretty sure that even if you didn't purchase it from them, they'd most likely be prepared to give you a few minutes of their time to introduce you to the machine and how to get it going :o)
Nov 28, 2014 | Targus CityGear Mini for Apple iPad 16GB...
What would be a reason for my ACER Iconia A1-810 tablet not powering on with a full charge?
If it doesn't turn on with a charged battery, you may have a broken logic board. If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Acer tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Acer Tablet Repair Services.
Nov 12, 2014 | Tablets & eReaders
My laptop wont turn on
I think your battery or your whole motherboard is fried. Does it make any noises? Do the fans start to run? Try unplugging your battery and only keeping your charger in.
Jun 02, 2013 | Acer TravelMate C300 14.1 XGA LCD Display...
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tablets & eReaders Logo
57 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
