Question about Maytag PYE2300AY Electric Dryer
Overheating cant touch the inside drum and smells like rubber burning plus a crunching noise but the exaust fan works and only crunches on heat not cold
  • 979 Answers
Your belt may be binding or off track.
Posted on Jan 24, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
I have cleaned the front filter but machine still won't drain water?
from your description, it sounds like you have a water stuck water pump. The crunching sound is probably foreign objects grinding againt the pump blades.
Aug 12, 2014 | Washing Machines
Strong burning smell coming from vents and from inside rheem electric central heat. Smells like rubber burning.
You must have to open it, try to clean it..and check for some eletric cables with short circuit or bad cables burning and overheating...check the motor fan and if it has a bad AC capacitor
check the photo, and you will have an idea.v4ndre_0.jpg Good luck!
Dec 06, 2010 | Heating & Cooling
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Burning rubber smell from Subaru Legacy
Please have your exaust pipes checked, perhaps a mount is burning. The catalytic converter can make a nasty odor when it is clogged. Check the wear on the serpintine belt.
Sep 18, 2009 | 2001 Subaru Legacy
Crunch on brake application
not all cars but some do when you take off the rotor itself there is little brake pads just inside this is how your emergency brakes work and if you have this then this is probably why you are having the crunching noice because one of the pads is cracked inside
Mar 31, 2009 | 2003 Chevrolet Venture Passanger
Crunching in rear of car
do you need new brakes
Jan 25, 2009 | 2000 Subaru Forester
Crunching and grinding
That noise come from the pump that drived the water out the drum. Since you don't have this noise every time, it's seems like it's cause an unclean filter issue. Cleaning the filter - should solve this issue. Before openning the filter, prepare a bowl and a floor cloth to avoid water's flooding. Good luck !
May 24, 2006 | Hotpoint First Edition FEW12 Front Load...
Maytag PYE2300AY Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
