Question about Broan-NuTone Heating & Cooling
Heater melts grill - Broan-NuTone Heating & Cooling
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
I just purchased a new portable gas grill. Burner Is melting.
take it back for a refund as it is not fit for the purpose
Jul 06, 2017 | Uniflame FG2204C Grill
Freezer temp flux's, items thaw and ice melts. I replaced the defrost heater and the thermostat. Now the freezed cools to 16 deg and now it is up to 29 deg. What should I look at next?
The defrost circuit is made up of the defrost heater, defrost thermostat and the timer. If the timer is keeping it on for too long then it could duplicate your symptoms.
BUT also make sure that the condenser grill (underneath your unit) is clean and air flow is good from front to back of the unit.
Jul 20, 2011 | Microwave Ovens
I have an Atwood hot water heater in a Bounder motorhome. When I turn on the switch to fire up the electronic ignition, it instantly blows the 12v fuse. An inspection of the unit shows wiring with melted...
My guess is that you may have or have had a spider web or other debris in burner tube that caused flame to back up, thus burning some wiring but, have someone experienced check it and clean it. The wiring if not burned too bad may be able to be repaired/spliced.
Jul 03, 2011 | RTO Atwood Water Heater - 6 Gal LP
2 of the 3 knobs on our Weber Grill partially melted also - can this be repaired? Same problem as Josh in a previous request.
Sounds like the gas valves for your burners are leaking, igniting the gas and casing the control panel to get hot and melt the knobs. It can be possibly repaired, but it will involve dismantling the control panel to access the valves and replacing them. You can get the parts directly from Weber.
Mar 06, 2011 | Weber Spirit? E-310 Propane Grill
I made hamburgers and the first time the cups melted due to the grease that was draining off. I followed the grilling instructions per the manual and had a greasy mess to clean up. Now I have to find...
The plastic cup melted because it was touching the hot plates and not because of the hot oil!
It is a poor design but with careful use can be fully functional, plastic is used to keep the cost of this budget product down.
Sep 02, 2017 | GE 4 in 1 Grill / Griddle
Knobs melt if both burners are set to high for more than 20 minutes in the summer.
Well, short of turning the burners down, so they are not on high, you might try wrapping the knobs in aluminum foil to prevent them from melting from the heat. But be careful, they may be hot to the touch, so where oven mitts or use a hand towel to turn it off. If they are melting, you may have some burner issues that need cleaning or replacing. If the grill is several years old, and it only recently has started doing this, then it's time to repair or replace the grill, if not for safety's sake. Hope that helps. Douglas
Jun 08, 2010 | Broilmaster Premium P3 Grill
Melted plastic on the heater element.
Safety overules your financial decision, get a new element.
Feb 11, 2010 | Cadet Manufacturing CADET SL Series Small...
Insufficient heat
I do beleive the heater element has reached end of life and need to be exchanged, you can contact the distributor in your area, or you can contact the manufacturer directly in Europe that will forward you to the nearest tech support center, do not forget to tell them where you live (city is enought) you have their contact in their webpage www.flama.pt.
PC
Jan 21, 2008 | Flama G1600 Indoor Grill
Heating & Cooling Logo
20 people viewed this question
Top Broan-NuTone Heating & Cooling Experts
Colin Stickland
Colin Stickland
brasseng
Level 1 Expert
Paul Carew
Are you a Broan-NuTone Heating and Cooling Expert? Answer questions, earn points and help others
