Question about Texas Instruments TI-83 Plus Calculator
How do I enter and graph the equation: 6 - 3/8y = x 2/3x + 1/4y = 4 Thanks!!
    Sergeant:
  • Texas Instru... Expert
  • 265 Answers
At first you have to slving this equations in explicit form y=f(x) and the graphing it. See captured images
Posted on Mar 03, 2012
    Problem Solver:
  • 8 Answers
Isolate the y variable in each equation and enter the result (what y equals) into y1= and y2=. or use matrices. repost if you want to learn how to do that. it doesn't involve graphing, sorry.
Posted on May 08, 2009
4 Suggested Answers
SOURCE: graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: My calculator will only graph one graph at a time.
This is simple... Back up all RAM, (press second+, then 2, then 1, press enter to back up something if backed up it will have a star by it) Then clear your RAM (pull out your batteries while the calc is still on or press second+, then 7, then 1)
Hope this helps!
Posted on Oct 09, 2008
  • 56 Answers
SOURCE: Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
Posted on Nov 12, 2008
How to graphing regarding ohter axes?
Add a graph .
In Documents Toolbox, select 3: Graph/Entry Edit
Unfold the menu and select Equation (not function). Enter your equation.
For the 3D part, I am afraid you will have to read the manual.
Jan 22, 2016 | Texas Instruments TI-Nspire CX CAS...
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Jun 11, 2014 | Texas Instruments TI-86 Calculator
In my Y= menu, any equation that I enter isn't graphed on my graph. At the top, by Plot 1 Plot 2 Plot 3, it says "X=" before them. Also when i do enter an equation, it says Error: invalid dimensions.
You must deactivate the Statistical plots.
Press [STAT].
In list that is displayed delect [4:PlotsOff] and press [ENTER]
Go to [Y=] editor to enter functions or press [GRAPH] if functions already entered.
Oct 20, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing an equation
Press the Y= key to invoke the Y= editor. Enter in your equation.
Press the WINDOW key to set the window parameters.
Press the GRAPH key to have the calculator graph the equation.
For more details and options, see the "Function Graphing" chapter in the Guidebook.
Nov 11, 2009 | Office Equipment & Supplies
I cant highlight both equations in Y= to graph
First thing to do before any new type of problem
1. Turn StatPlots OFF : press [2nd][STATPLOT][4:PlotsOff] [ENTER]
Second thing: Clear the statistical lists
2. Press [2nd][0][PGRM] DownArrow to point to ClrAllLists.
3.Press [ENTER][ENTER]
Third thing : Configure the graph type to be FUNCTION graph
4. Press [MODE]. If FUNC (on fourth line) is highlighted. Press [Y=] and start entering the functions.
5. If FUNC is not highlighted, use Down arrow till 4th line, highlight FUNC and press [ENTER]. Press Press [Y=] and start entering the functions.
Fourth thing: Enter function and select them for graphing
1. As you start entering the function Y1=, notice that the = sign becomes highlighted. Press [ENTER] when Y1 is typed in. Make sure the = sign for Y1 remains highlighted as cursor moves to Y2=.
2. Keep entering the functions and verifying that their = signs remain highlighted as cursor moves to another equation.
3. When finished press [ENTER]
4. Look at the graph style for each function: it is a bit of line to the left of each Y. Here is a picture of all the 7 styles.
To set a graph style, highlight the style to the left of the Y, and press [ENTER]. Each time you press [ENTER] you see a new style, in the order shown on picture.
Avoid the style of Y6, it is bubble, and as such will burst and disappear once graph is finished. Avoid also the triangular ones (for Y3 and Y4) they will shade areas of the graph, and may hide other functions.
Fifth thing: Graph Functions.
1. You can press [GRAPH] to see your graphs.
2. If one curve is missing (and you have not set its style to be rhe bubble), it may be due to the Window dimensions.
Sixth Thing: Set Window dimensions and Zoom.
1. Press [ZOOM][6:ZStandard] to use standard window dimensions.
2. If curve still missing, Press [ZOOM][3:Zoom Out] to zoom out so that you may be able to see a bigger range for the functions.
3. If necessary press [WINDOW] and set the Xmin, Xmax, Ymin,Ymax to values of your own.
Dimensions must obey the conditions: Xmin < Xmax, and Ymin < Ymax.
Hope that helps.
Nov 09, 2009 | Texas Instruments TI-84 Plus Calculator
Graphing function will only graph one equation at a time. Why is this and how can I fix it? Thanks!
  1. Once you enter an equation, the corresponding equal sign is highlighted by default.
  2. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted.
  3. If one is not highlighted, move the cursor on it and press ENTER.
  4. If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER].
  5. Command PlotsOff echoes on main screen.
  6. Press [ENTER], screen displays Done.
  7. Restart the graphing procedure.
  8. If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
You shouild make it a habit to clear the RAM every time you start a new type of problem.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-84 Plus Calculator
How can I graph two equations at once? My equal sign will not stay highlighted for two equations. It just graphs one at a time
Once you enter an equation the corresponding equal sign is highlighted by default. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted. If one is not highlighted, move the cursor on it and press ENTER.
Command PlotsOff echoes on main screen. Press [ENTER], screen displays Done.
Hope it helps.
Oct 14, 2009 | Texas Instruments TI-84 Plus Silver...
Graphing
i had the same problem .... just go to apps and go all the way down transfrm and click it then click the uninstall button !!!
Apr 01, 2009 | Texas Instruments TI-84 Plus Calculator
Hope this helps!
Oct 07, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
204 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
