Question about Dell Dimension 2400 PC Desktop
Clicking sound coming from mother board
When i power up the computer a clicking sound i thought was coming from the hard drive, i tried removing the power from the hard drive to see if this would isolate the problem to the hard drive, but the clicking sound and a yellow light were flashing on the mother board it will not power up, what could be wrong?
  • 66 Answers
Check your memory if the sound is continous beeping or your Video adapter. try to clean it and installed it again if problem occured use another memory or VGA for testing..
Posted on Jan 23, 2009
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
The Hard Drive has jammed/seized up. Is making a clicking noise and will no start up.
A clicking sound from a hard drive is one sound you never want to hear. It means the hard drive has failed. Replace it.
Sep 01, 2011 | Computers & Internet
Tech says i need new motherboard computer won´t turn on
Before you buy a new mother board, (the L300D-13S board is around $185 from China), remove your battery, leave it for about 5 minutes. Use only the Mains power supply and see if it will switch on.
Fit the battery, plug in the Mains Charger and see if the battery charge light comes on. If it does and it won't give you a screen or flash the hard drive light or power up the hard drive, then I am inclined to go along with a replacement Mother Board.
The laptop has to complete the POST and if it doesn't that usually points to Mother Board problems.
Were you trying to upload a newer version of the BIOS before it failed?
Good luck but check ebay and beware there are some really dodgy frauds out there.
Oct 20, 2010 | Toshiba Satellite M35X-S1142...
Computer comes on half the time, it powers up but no monitor, mouse, and keyboard function. the other half of the time it comes on and then freezes up about a minute or so on boot up, and half the time...
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU or replace it
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
then uninstall some unnecessary programs
then click start?run type?cmd then type?chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
hope this helps
sounds like your computer needs a major overhaul
Sep 21, 2010 | MSI RC410M-L Motherboard
Motherboard LED on, board will not turn on.
Clicking noise!! If its a lil similar to the peeping sound it must be the RAM try removing the Ram and then cleaning the Slot maybe interchange the slots. If not i guess ur RAM's a goner.
May 20, 2010 | Intel D945GNT Motherboard
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Swapped hard drive into new casw and now it wont boot up
This is due to a hardware conflict.
The system drivers on the hard drive are for the old mother board and devices,You will have to reinstall OS while it is install on the new mother board,The computer cannot boot to a drive that is loaded to another system unless all the devices and drive are identical.
Please rate this a fixya
Feb 13, 2009 | EliteGroup 848P-A Motherboard
Hi eakesj:
A number of things here should be checked.
First shut down and remove all cards, and power connections to all the drives such as cdroms, hard drives.
The power supply should also be looked at and tested for correct voltages on each wire. This can be done with a voltage meter.
Turn on the power and see if you can get the machine to start to the bios screen. (this will work if you have a video processor on board, if you have a video card, you will need it to use the monitor).
If that will not work, then you have more problems than you thought at the beginning.
If the mother board will not work at this point, then you have problems with either the mother board or the cpu processor. There is a possibility that there are problems with the memory modules.
So, if you have only one memory module, then I would remove the memory, carefully clean the contacts, (a clean pencil eraser can work, if you are careful, and do not press very hard) and then plug the memory back in and try again. Also if you have extra modules of the same type, try one for testing.
If you are still having the same problems, then the mother board or the cpu is the problem. At this point you should consider if you want to continue and repair or buy another mother board of the same size. If you buy another kind of mother board, remember you will have to re-install your operating system over the original one to get the complete setup and the bios to work correctly with it. Many times this can be done, but you risk losing data (you will lose all data in MY DOCUMENTS), and may have to completely re-install the OS. You may want to install the drive in another computer as a slave and back up any data you want to save before you proceed.
If you decide to continue with your original mother board, and still have problems, then the cpu or the mother board is suspect. To test the cpu, either test your board with another cpu which is compatible, or check the mother board with another mother board of the same exact model.
Hope you find the problem.
Feb 03, 2009 | eMachines T6534 PC Desktop
Power up
pull everthing off board but power supply ram cpu and heatsink. then try to power unit.
May 08, 2008 | E-Machines eMachines Desktop PC
Dell Dimension 2400 PC Desktop Logo
71 people viewed this question
Alun Cox
