Toshiba TV, I can't tune channels, when I go to
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
Check whether the input is selected to AV. In AV mode, no tuning is possible. It it is in this mode now, switch it to TV mode.
Posted on Jan 13, 2013
  • 86 Answers
SOURCE: tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Posted on Jan 30, 2008
SOURCE: Sharp TV CX51N3 How to tune channels
Here's the link to the full user manual.
Cheers
Rich
http://support.sharp.net.au/downloads/opmanuals/CX51N3om.pdf
Posted on Jun 01, 2009
SOURCE: unable to re tune the tv
http://www.fixya.com/support/t933113-sony_trinitron_tv_model_kd_28dl10u
Posted on Sep 30, 2009
  • 231 Answers
SOURCE: Cannot set my toshiba television to the input channel manually
if you go to channel 2 then channel down the channels between it and the highest are your input channels hope this helps
Posted on Apr 14, 2010
  • 2509 Answers
SOURCE: The video input channel capability
Hmmm a wild guess perhaps you should try to add channel 0 (zero)?
Posted on Mar 06, 2011
Volume tv goes down its own
Depending on your TV, here are the generic steps Toshiba has outlined to reset your TV:
1. Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
2. Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
3. Highlight the SYSTEM STATUS menu at the top.
4. Highlight SYSTEM INFORMATION below and press ENTER.
5. At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
6. Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
Apr 09, 2014 | Toshiba Televison & Video
Auto tuning digital tv lcd Sharp LC-32LE345X
Maybe your Sharp TV wants you to go back to setup and go through the whole routine again.
Nov 21, 2013 | Sharp Televison & Video
I have got a new Toshiba Regza I have tuned it in but don't seem to have got all the channels can u help
you will need first to configure the antenna sources where you want to program channels. and then you can add channel through your remote control. to add channels in the channel memory, first press MENU and open the set up menu and then highlight installation and press enter. a new set of installation menu icons will appear on the screen. open the terrestrial menu highlight channel add, and then press enter. the list of channel program from the antenna source that you select will appear on the screen. to add now a channels to the channel memory, highlight unchecked box next to the channel number you want to add, and then press enter to check the box.to save new settings highlight done and press enter.
Apr 19, 2011 | Toshiba Televison & Video
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
How do I do a channel scan?
Press Menu on the TV (second button from the left) or the remote. Use the Vol + / Vol - buttons to highlight Tuner, only available when the input is the TV (press TV/AV to get to the correct source) mode. Press Ch+/Ch- to highlight AutoProgram and then Vol+ to start the search for channels. The TV will show Tuning Finished when done and then go to the lowest channel found. If you want to add or remove stations, tune to the desired channel, then press Menu, and highlight Tuner, Ch+/Ch- to highlight Add/Erase, then Vol+/Vol- to set Add or Erase. Press TV/AV/Exit to get out of the menu.
I hope this helps.
Jul 28, 2010 | Philips Magnavox 27MS343S 27" TV
I dont know how to tune in channels on my remote
Press MENU,then press < or > to display SETUP menu, press V until TV/cable is highlighted. Press < or > to highlight TV or cable depending on which you use. Press V to select CH Program,press < or > to start channel programming,when completed appears,press CH + or - ...hope this helps..
Mar 24, 2010 | Toshiba 27A33 27" TV
Tuning
after tunning,delete the channels you dont like in the channel settings menu.
Apr 15, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Feb 21, 2008 | Toshiba D-VR650
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
