Question about Dell 924 All-in-One InkJet Printer
Why are the copies are coming out blank - Dell 924 All-in-One InkJet Printer
  • Dell Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Jan 13, 2013
Replace toner and drum and when i make copies they come out blank
This comes from the manual for your device:
A blank sheet is ejected.
You placed the document facing the wrong way when using the copier.
The other party placed the document in their fax machine the wrong way. Check with the other party (KX-MB781 only).
Try putting a page in and seeing if it copies blank and then putting it in the other direction. Have you had the same issue with printing?
If everything comes out blank it is the fuser or heating element.
Oct 25, 2012 | Panasonic KX-MB781 Laser Fax, Copier,...
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Copies come out blank
Scanner lock is on. Should have heard a noise or popped an L code but I have seen this happen as well.
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copier is not copying
possible broken charging wires (corona wires) (chargeing wire) no charge on the drum will not pull developer or broken (transfer wire) will not pull image off drum resulting in blank copy
Dec 19, 2008 | Office Equipment & Supplies
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Workcenter xd103f copy comes out blank
Which cartridge did you change? If its the toner cartridge, make sure none of the packaging materal is left on it, same with the drum cartridge. First and simply remove and reseat the cartridges.
What I suspect with the blank copies is a broken transfer corotron wire.
Open the right side door. On the bottom you will see some whit plastic rollers. Above that you will see an opening about 1/2 inch wide. There is a very thin wire in that channel. That wire has probably broken causing your blank copies, I highly suspect that is broken.. That wire when it is dirty also causes really poor copy quality.
Also clean all the mirrors and glass well. That will cause poor copy quaility issues.
Mar 12, 2008 | Xerox WorkCentre XD103F All-In-One Laser...
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
111 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
