Drain clogged My washer rarely makes it through the drain cycle. Since it does sometimes, I believe the drain pump is fine. I have cleared a potential clog in the outgoing line from the drain pump, and can blow through the drain hose (which sometimes allows the system to drain the rest of the way). Is it likely that the incoming drain to the drain pump is clogged? If so, how can I access it? Is it a hose or a valve style drain?
    Sergeant:
  • 291 Answers
What is the machine?
Posted on Jan 13, 2013
  • 2 more comments
  • nfolsted
    nfolsted Jan 13, 2013
    Washer model # is MVWX500XW0
  • nfolsted
    Maytag, sorry
  • B.H. Countryman Jan 13, 2013
    Most likely it is a clog in the hose between the tub and drain pump. Or a failing drain pump. They are accessed from underneath, either by tilting machine or laying the machine down on it's front. Use a towel laid out to prevent scratches.
    Go here:http://www.youtube.com/watch?v=vbLAory7i... It says Whirlpool but don't worry about that yours should be the same. Instead of the replacement procedure though your goal should be to remove and inspect for objects in the hose going to the pump and then check the pump impeller. It should be straight and turn though with resistance about every 1/2 turn. Let me know.
SOURCE: Duet error code F 02.
Just had this problem. Remove the kick plate in front of machine. The drain pump filter maybe clogged. Turn the white screw to remove filter, but be sure to have towels or a bucket handy. I clean mine out and now is working fine.
Posted on Dec 11, 2007
gittos73
  • 244 Answers
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
Posted on Dec 12, 2007
the dr
  • 447 Answers
SOURCE: Front Loading Washer won't drain
The problem is most likely change in the drain pump and sump area (rubber boot going from tub to pump). It is axcessed by removing the lower front panel. Disconnecting and reconnecting the hoses to the pump are real tricky!!!!!!!!!
Posted on Jan 16, 2008
SOURCE: WTW6600SW2 Won't Drain
We had the same problem. In our case a penny got down under the tub and into the pump. It caused a crack in the pump and it could not get the suction it needed to drain. A new pump solved the problem. Parts and labor to the tune of $195.
Posted on Nov 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 06, 2010
I have a LG Dishwasher, Model LDF7551ST invert-er direct drive, and it's been getting this (OE) error, it worked fine for about a yeaR
Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Jan 04, 2016 | LG Dishwashers
Why does it quit randomly during cycle?
If you cleared the drain pump trap of obstructions, and the pump still runs fine(without rattling from a loose or damaged impeller) then most likely you have fixed the problem. The washer will not spin if it can't drain--and if the water is draining too slowly, it will time out and give an error code for "slow drain". For any items such as bras, underwear, socks, baby socks, stockings, pantyhose, etc, use a netted clothing bag with a zipper to prevent those types of things from getting pulled in-between the basket and tub and then making it to the drain pump trap. These things are notorious for clogging pumps on front load and top load HE washers!!
Aug 02, 2015 | GE Washing Machines
My fisher & pay keel washer wa37t26gw2 won't drain, I have already tried taking off the drain pump checking it and making sure all hoses clear. When I tried to start a load after draining by removing...
Fisher/Paykels are notorious for bad drain pumps. If you hear any kind of squeeling, grinding, chattering, or such while it is drying to drain, you have a bad pump. P/N 479595
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber=268462&CatalogId=1&CatalogDetailId=35&NSM=Y
If while trying to drain, the water is emptying back into the washer tank, you have a bad or clogged diverter valve. p/n 426862P
Apr 07, 2014 | Washing Machines
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Washer displays Ld and won't drain. won't restart or anything. kenmore oasis
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem.
You can use a diagnostic test to start the drain pump. To start this diagnostic test, press the following keys in this order: SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL. The display should show "dt" after this key dance. Press the JEANS/COLORS key to start a 60 rpm spin and drain test that will terminate after 40 seconds. Listen for the drain pump. It should be running during this test. Also listen for unusual noises from the pump that could indicate that it is clogged. You may be able to drain the water from the washer using this diagnostic cycle depending on the severity of the clog or failure. If not, you may need to manually remove the water. If you are able to safely access and clear a clog in the drain pump or drain line, you may be able to repair this problem yourself.
Jan 07, 2011 | Kenmore Washing Machines
I have a lg washer that sometimes it drains and other times it doesn't. the filter is clean and when it doesn't drain it makes no noise like it is tied up. it just sits silent. it fails to pump at...
Have you removed the hoses to the drain pump and looked for any kind of obstructions.You will need to make sure there is nothing blocking or slowing the impellar wheel.
Dec 29, 2010 | LG WM-2277HW Front Load Washer
Cuts off when drain cycle starts.
Your problem could be with the "timer".
Feb 24, 2010 | Maytag Washing Machines
Hi, During the express wash cycle the machine stops draining and flashes F02. When I unplug the machine for a few minutes and plug it back in,I try to drain it by pressing rinse/drain cycle but it will not...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 05, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
If you can hear the washer move into the cycle where it drains and all other cycles work (ie spin, wash ect). Then you either have a faulty pump or a clog. A pump change is a relatively easy fix. How do...
Remove the front panel. There is a short hose that goes from the tub to the pump. Sometimes you can remove the clog by gently squeezing the tube with the machine on and it will clear. The other option is to get all the water out of it then remove the tube to clear it out.
Jul 04, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
