Question about Gateway DX Computers & Internet
The hard disk on my gateway dx4820-05h crashed and had to replace it with a new one. I don't have a recovery disk so I tried to install windows 8 but i'm unsuccessful. During the install process, when the windows 8 OS is already configuring the system, my pc would suddenly shutdown. When I turn it on, I would get an error message saying "computer had an unexpected reboot, insert installation disk and re-install". done it several times but still got the same result. any suggestions???
    Master:
  • 344 Answers
You will need to buy another licensed copy of windows 8 if you didn't burn the recovery disks while the system was operational.
You might also be able to buy the recovery disks from gateway them-self. Contact gateway customer support for more information. Make sure you have the make and model number for your machine and be SURE they have the correct information or you might get a disk for another system.
Posted on Mar 12, 2015
rickatnight1
  • 72 Answers
SOURCE: Windows XP Home Edition on HP Pavilion a367c
Are you able to successfully enter Safe Mode? Are you getting a brief blue screen before the computer restarts?
A possible solution (if you can't get into Safe Mode to further diagnose the issue) is to repair the Windows installation with a Windows XP Home CD. If you know someone with such a disk you can use that with the product key that should be on a sticker on the back of your computer. Otherwise, HP should be able to send you an XP CD since you have an authorized copy of Windows on your computer.
Posted on May 14, 2008
lcheek1
  • 6 Answers
SOURCE: Gateway OS Restore for Win XP Home fails.
try alternate drivers for the intel chipset install dont load the ones on the cds
Posted on May 20, 2008
  • 90 Answers
SOURCE: I bought new laptop and
Try booting your system with the Windows installation CD.
Thank you.
Thomas
Posted on Nov 16, 2008
LMITC
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Posted on May 27, 2009
mikeramesar
  • 37 Answers
SOURCE: error auto-sensing primary hard disk drive0
Your hard drive has failed, you will be best to bite the bullet and buy a new hard drive and have it reloaded, not the news you wanted to hear but that's your best option to get THAT pc running again.
Good Luck!
Posted on Dec 28, 2009
I have an HP Compaq tc4400 that I got from an old friend that had no use of it . but when I turn it on it says Non-system disk or disk error replace and strike any key when ready but I dont have a disk ....
It sounds like there's a problem with Windows (assume that's the operating system it used to have). I think you'll need to get a Windows install disk. Installing Windows is actually not that hard, and it sounds like you've got nothing to lose.
If you don't have access to a copy of Windows, why not try out Windows 8 - http://windows.microsoft.com/en-AU/windows-8/release-preview
I assume it'll only be free for a few more days as Windows 8 will be released in under a week now.
Hope that helps.
Cheers,
Derek.
Oct 21, 2012 | Computers & Internet
Windows error recovery on toshiba satellite
Sounds like your hard drive has crashed. You will need to replace it.
You can try to run the Check Disk Utility to see if it can repair the drive.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 01, 2012 | Toshiba Satellite L305D-S5895 Notebook
My Gateway m6750 crashed and I need to get an operating system back on to the new disk., I do not have any backup. but I do have another m6750 that works great. Is there a way to back up the operating sys...
I am assuming the operating system is Windows Vista ?
Windows has a mechanism that detects the hardware on your computer and will most likely get upset that it has been copied onto another P.C. Most Windows O/S on Laptops are OEM licensed which means that if the P.C is non working the licence stays with the now non working p.c.
suggest trying to recover crashed hard drive from hidden recovery partition http://gateway-us.custhelp.com/app/answers/detail/a_id/34866/session/L3RpbWUvMTUxNjIyOTk0OS9zaWQvZlVldDZ6MDR5YTczZzNHSWI1aCU3RVZIeER6ZENWdmMxRzVjV0dOVkNfaWRJZTV1MU9KMXBOWkw2cEpfb2N5JTdFM0NHSmJSWW8zdThoSGs4RnNUQzQyWUVLcGhhUDA1bTZEVE1jRm1yREtLaFZrVGI0RnV5clQ2UU9ZZyUyMSUyMQ%3D%3D
then try getting a recovery cd for your particular serial number and model number from http://www.gateway.com/gw/en/US/content/contact-support
to use on your new hard drive
Jan 17, 2018 | Gateway M-6750 PC Notebook
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
Jun 30, 2011 | Gateway GT5670 Desktop PC
I want to replace hard disk of my presario v6700, which has a buitin recovery disk from the company. i made recovery disks already. but when i want to install windows from the recovery disk on the new hard...
This error is when you try to use OEM recovery disks with a non OEM hard drive. The company recovery disks will not work, they do this to prevent software fraud. Sorry to say you will have to purchase a copy of windows and start over :(
May 05, 2011 | Computers & Internet
I'm looking for recovery disks for a gateway MX6450 my hard drive crashed.
The system recovery process for your computer is stored on your hard drive. As long as you are trying to reload your hard drive, not replacing it then you can access and run the recovery application without going into windows.
The access the system recovery without going in to window:
Power your computer off.
Disconnect all external devices including printers and pc-cards (external mouse and keyboard can be attached)
Power you system on and watch very carefully for a message that says 'Press F11 to start system recovery'
Press F11 as soon as you see this message.
From her you can go through the recovery process.
Nov 14, 2009 | Gateway Computers & Internet
Computer crashed, not sure how to recover it and what to use.
TRY BOOTING WHILE PUSHING F10 OR F11. MOST GATEWAY AND EMACHINES HAVE A RECOVERY PARTITION FOR A BACK TO FACTORY RECOVERY.
May 28, 2009 | Gateway GT5012 PC Desktop
Computers & Internet Logo
156 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
