Question about Microsoft Windows XP Home Edition
Can not "turn on" disk cache
I am running Windows XP SP2, with latest fixes per the patches from Microsoft, 1.5 GB RAM, Pentium 4 @ 2.0 GHz, three hard disks with 21.1 GB free space on system drive (c:). A few months ago I started having performance problems. Hibernation was painfully slow. When hard disks were idle and they had to start again because of demand, the mouse and all other activity would freeze up for a short while until the HD operation was completed. Leaving on the HD all the time helped a little, but only a little. About the time the HD cache stopped working, I installed an ATI Radeon 9200 dual-head ATI graphics adapter and a second monitor, with latest AGI driver and Net Framework 2.0 (1.1 is still installed). Can't understand what, if anything, this would have to do with disk caching... I selected Properties on my C drive, "hardware", the first disk specified (Quantum FireballP AS40.0), properties for that drive, then "Policies", and got screen "Write caching and Safe Removal." The contents of the screen were grayed out, as if the hard drive did not provide the "Optimize for performance" or "Optimize for quick removal" choice. While the enable cache option was clicked, both were grayed out, which is indicative of current performance. Any suggestions? I really find hibernation helpful, and want to continue to use it.
  • Bob Morgan
    Bob Morgan Jul 07, 2007
    Tried defragging drive "C" ... didn't help. Turned off hibernation (which removes hyperfil.sys from root of "C" drive), rebooted, turned on hibernation (which reinstalled hyperfil.sys) - that didn't help. Write cache for the system drive (as well as the other two drives) is still off and there is not way to turn it on (options switches are in light gray -- controls do not respond).
Try unistalling hibernation first and repeat the normal procedure, next install back the software and check the performace.
Posted on Jul 07, 2007
SOURCE:
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
Jul 11, 2011 | Acer eMachines Black EL1352G-41w Desktop...
I have a dc7600 and im trying to find out how to identify the what type of mother board it has so I know what to do next, so my question is how do you identify what motherboards in it without downloading...
The specs for your computer are as follows:
Processor
Intel® Pentium® D Dual Core Processor 820
• 2.80 GHz, 2 x 1 MB L2 cache, 800 MHz front side bus
Operating system installed
Genuine Windows XP Professional SP2
Compatible Operating Systems
Genuine Windows 2000 (Web Support), Genuine Windows XP Professional SP2, Genuine Windows XP Home SP2, FreeDOS, SuSE Linux 9.3
Chipset
Intel® 945G chipset
Standard memory
1 GB (512 MB x 2)
Maximum memory
4 GB DDR2-Synch DRAM
Memory type
DDR2 PC2-4200
Memory slots
4 DIMM
Memory Upgrade
Expandable to 4 GB through three industry-standard DIMM slots
Chipset
Intel® 945G chipset This is *********** board the below link lead to the specs for your motherboard.
http://ark.intel.com/chipset.aspx?familyID=8765
May 18, 2011 | HP Compaq dc7600 Small Form Factor PC...
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
I have a hp ellitebook 8440p and it shutsdown when running autocad lt2009
1. Autocad uses a lot of memory. Make sure you the maximum ram installed. You can check the virtual memory if that does not work.
2. Shutting down in the middle of an operation can be that the unit is overheating. Use a cooler, docking station, or stand the book on the side with the laptop lid open about 45 degree angle. Leave it on to see if it shuts down within the same time as when it was laying flat with Autocad running. If it takes longer, the problem may be a fan not cooling properly or allow more cooling during the use of Autocad.
Mar 07, 2011 | Autodesk AutoCAD LT 2009 Full Version for...
I have LatitudeD510 and my disk makes lot of noise. Its on Windows7 and I think the disk is a Hitachi - HTS541040G9AT00
HI,
chances are that you simply do not have the resources to run windows 7. These are the basic (recommended minimum), for windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor.
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit).
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit).
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • 1 more GB of RAM & 15 GB more HDD space to run 7 in XP Mode.
These are the typical resources that come with your machine.
D510HI
  • Processor Pentium M 1.73 GHz
  • Ram Installed Size 512.0 MB
  • Technology DDR2 SDRAM
  • Hard Drive 40.0 GB
  • OS Provided Microsoft Windows XP Professional
It would probably be advisable to go back to XP
Good luck
Jan 07, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Video card
the requirements are
FOR WINDOWS XP
  • Windows XP (Service Pack 2)
  • 2.0 GHz P4 processor or equivalent
  • 1 GB RAM
  • At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
  • 128 MB Video Card with support for Pixel Shader 2.0
FOR WINDOWS VISTA
  • Windows Vista (Service Pack 1)
  • 2.4 GHz P4 processor or equivalent
  • 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
  • Intel Integrated Chipset, GMA X3000 or above.
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
So what does your computer have?
Jun 02, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
426 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
