Question about Maytag Neptune MAH5500B Front Load Washer
Clicking sound is it normal for a clicking sound through the whole cycle? it sounds like a click and then like someone is spinning the wheel like on the show Wheel of Fortune. I bought the washer and dryer set from someone.
    Problem Solver:
  • 5 Answers
Sounds like it probably has a bed bearing on the tub . pretty expensive most usually replace the washer.
Posted on Jan 23, 2009
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Why does my washer (maytag mah5500bww front loader) make noise during the wash/rinse cycles but not during the spin.?
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Apr 30, 2014 | Maytag Neptune MAH5500B Front Load Washer
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
When I turn right something sounds repeatedly I think it might be in the wheel but I am not sure. The sound I hear is like there was a soft hit that i can also feel in the steering wheel. I hope someone...
This sounds like your CV Axles are going out. When they start going out they click during turns, and eventually will break. Replace your CV Axles and all should be back to normal.
Jul 10, 2010 | 2004 Mini Cooper
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clicking noise under dash
Nah, no msjor wire storms. If your lights are flashing, then I doubt its the flasher. It is more than likely your ABS system cycling. hAVE YOUR WHEEL SENSORS CK'D / ADJUSTED FIRST. gOOD lUCK.
Jun 03, 2009 | 2000 Lincoln Town Car
I have a clicking sound on my maytag neptune washer. it clicks through the whole cycle, is that normal? it sounds like clicking and then spinning, like wheel of fortune show
I would check the agitator,( the middle part of the washer that turns back and forth, hence agitator) and see if it is snug, by popping off the cap at the top of the agitator with a flat-head screw driver, and then checking to see if the nut is on tight or the four little hooks, that hook onto the jagged teeth, around the top of the agitator. I hope that this helps.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
