Question about Toshiba Satellite A55-S106 Notebook
Wont boot passed windows screen and keeps reseting.
I went into bios and disabled cache, reboot and keep getting unmountable boot error. Please help me i need my laptop!! and i dont have the boot disk. help me please
  • cig2412 Jan 23, 2009
    no i keeps reseting
    yes it gets to safe mode options but wont go into safe mode either i get the error message(nlue screen) or it reboots
  • 837 Answers
Does it get to a windows boot up? I.E. safe mode options etc or not even that far?
Posted on Jan 23, 2009
  • Jay Glendenning
    Jay Glendenning Jan 23, 2009
    In the safe mode screen there is an option
    Disable automatic restart on system failure
    Select that .. let me know what that error(s) is .. should be a STOP ERROR
Nand storage unmounted and wont mount nextbook 7 in
Mine was having he exact same problem. All I did was hard reset it, wipe the cache, and wipe the media partition.
First, turn off your nextbook.
Hold both the POWER button and the VOL UP button until the screen the screen comes on. Once its on, you can remove your finger from the POWER button but still keep it on the VOL UP button until the screen goes to a black BIOS screen.
From there, use the VOL DOWN button to scroll to the "Factory Reset/Wipe" option, then press POWER to enter.
Scroll down to Yes to confirm once more and that should be it for the Factory reset.
I recommend you proceed to the "Wipe cache" & "Wipe Media partition" options to be on the safe side.
I hope this solves your problem like it solved mine.
Dec 25, 2013 | Nextbook Tablets & eReaders
Unmountable boot
Hi
You will need to get the original windows disk you was sent.
Put it in the laptop and run the 'RECOVERY CONSOLE'
this should bring up a command line, (command prompt)
Type :
1. fixboot
2. chkdsk /r /f
If they both fail you will either have to put your hard drive on a cradle and write another boot directory to it, or you will have to reformat it.
Mar 30, 2013 | Dell LATITUDE Computers & Internet
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
I have got Sony Vaio. When I installed Intel Graphic driver and rebooted, the laptop don't get booted. The screen displayed a message as: System BIOS Shadowed System VIDEO Shadowed. After waiting for...
Please download and Run the BIOS update utility for resolve this issue. You can download it from the link below.
Download
If the problem still persist, reboot the Computer and keep tapping the F2 key when VAIO logo appears on the screen to enter BIOS mode. You can manually disable the function System and BIOS Shadowing. This will resolve the issue.
Good luck..:)
Sep 20, 2010 | Sony VAIO VGN-CR220E/W Notebook
STOP: 0x00000034 blue screen error... says to disable bios memory options such as caching or shadowing but I can't access windows it keeps restarting and going back to blue screen..... safe mode dont work,...
This is a cache manager error or a missing DLL file error. This might have heppend as a result of some hardware of software changes that you might have made recently. You can either install the removed drivers once again or need to run a repair reinstall of windows to get the curropt dll files working again.
http://www.jj54.com/Fix-Error-Number/0x0000/
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 19, 2010 | Microsoft Windows XP Professional With...
Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
and then replace this will reconfigure your
motherboard and hopefully solve your problem.
Feb 15, 2010 | Dell Dimension 2400 PC Desktop
There are several options. This is what I would do: Go to the E-Machines site and get the fix from them. If they don't have it I would down load the files to the hard drive and burn a CD. When you make the cd ensure your folders are labeled DISK1, DISK2, ... there should be 1 folder for each disk and then make a folder DSK and put all the files in that folder. As long as none of them share a name you should be good. The cd will need to be Bootable. Boot the machine from the CD and try running the fix from teh DSK folder. If that does not work. Reboot the machine from the cd, Open the Disk1 folder and startt the program. Now, if none of that works or you feel you haven''t really put anything on the computer you need to keep the fastest option to get back up and running is to put the CD that came with the E-machine in the drive and reboot the computer. Choose Repair system or Restore to Factory settings when the menu appears. One of these options will work if your harddrive is not damaged.
Aug 27, 2009 | eMachines EL1600-01
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
PC Cannot Boot
Common windows problem,you need to wipe your drive and reinstall your operating system
Jan 08, 2009 | MSI K8MM3-V Motherboard
Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Dec 13, 2007 | Dell Latitude D600 Notebook
Computers & Internet Logo
155 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
