Question about Cobra 25 LTD 40-Channels Base CB Radio
No power when i plug in fuse keeps popping,even with a 30 amp. like something shorted out on in side
  • 585 Answers
You are so right, there is a short.. This is usually a result of hooking the power leads up in reverse-polarity. As a result, the protection diode shorts, preventing the death of the rest of the radio. This diode, a solder-in part, is found on the pc board, next to the red wire that connects from the DC power jack. A 1.5 amp general purpose diode will work. And don't use a 30 amp fuse.
Posted on Jan 23, 2009
30 amp fuse keeps blowing
check for hot wire with cut in insulation either by frame or going through frame probably red or black wire also check lights and plug
Sep 20, 2015 | Jayco 2014 White Hawk Ultra Lite 24RBS
Why does AM2 30 watt fuse keeps popping on my 1999 toyota tacoma 2.7
fuses keep blowing because the current flow exceeds the rating of the fuse . That means that something is shorting out . Find the circuit that the fuse protects and check the wiring for dead shorts or a unit that is shorting out internally.
Aug 13, 2014 | Cars & Trucks
1997 Harley Ultra Classic 30 amp main breaker pops while riding. Also blows 10 radio power fuse
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 19, 2012 | Harley Davidson FLHTCUI Electra Glide...
What would cause the 30amp ignition fuse on 95 ford ranger to blow?
WHEN A FUSE BLOWS YOU HAVE A SHORT OR SOMETHING SHORTING OUT IN THAT CIRCUIT.MANY THNGS CONTROLLED BY 30 AMP FUSE PCM POWER RELAY, POWER WINDOWS.LOOK ON FUSE DIAGRAM COVER FOR 30 AMP FUSE THAT BLOWING SEE WHAT CIRCUIT THAT FUSE CONTROL OR LOOK IN DASH OWNERS MANUAL SEE WHAT THE 30 AMP FUSE CONTROL SEE WHAT CAUSING IT TO BLOW.
Sep 11, 2011 | 1995 Ford Explorer
Yes my fuse for my wipers keeps blowing and my wipers turn on when i plug fuse in even know the wipers are turned off.
The power distribution box in the engine compartment # 6 , 30 amp mini - fuse , front wiper motor , front wiper relay , front washer pump , FEM ( also # 7 , 25 amp mini - fuse , rear wiper etc. ) The owners manual shows to disconnect your battery cables before servicing anything in the PD BOX
your relay could be shorted which makes the fuse keep blowing
Sep 05, 2011 | 2001 Ford Windstar
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
1995 camry running fine up until i parked it for 2 hrs ignition fine timeing belt fine keeps popping 30 amp fuse could that fuse block were the harnesses are plugged to under the dash go bad?
It takes a short circuit to blow a fuse. You could try to disconnet thingsuntil it stops, but that is slow. Better if you buy pulse generator to replace the fuse, then move probe over wire until puse stops at the short in the wire.
Harbor Freight might sell a short circuit test probe and pulse generator.
Jun 26, 2009 | 1995 Toyota Camry
2001 crown vic keeps burning 30A PCM relay fuse
have fuel pump checked i have known a bad fuel pump shorting out causing pcm fuse to blow.
May 10, 2009 | 2001 Ford Crown Victoria
No power is going to my amp
This sounds like there may be something loose inside of the amp. Please dont go pokeing around in side there your self. Unless you are a fix it kind of person. There could be electric charges , even if it has been unpluged for days. Have some ck. it out if you can not. I bet ya its not to serious , all so ck the fuse. Some times they will play around just befor they blow out for good . keep on playing DFD
Mar 29, 2009 | Line 6 Spider Iii 30
Cobra 25 LTD 40-Channels Base CB Radio Logo
62 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
