Cars & Trucks Logo
Posted on Jan 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2006 Suburban, rear windshield wiper not working, can hear motor/pump trying to work but no movement.
  • Anonymous Mar 20, 2014
    wipers don't work
  • Anonymous Apr 01, 2014
Anonymous
Level 3:
President:
  • Master 1,450 Answers
  • Posted on Jan 23, 2009
Anonymous
Master
Level 3:
President:
Answers
1450
Questions
Helped
796840
Points
4747
With wiper on try to wiggle the wiper arm with your hand. if motor is stuck this will sometimes jar it loose. you may need to do this for a minute as the wiper is a delay system. also if you can move the arm thru its sweep then it is just the wiper arm loose if this is it remove cover at base and tighten nut
When I turn the switch to my 2006 Cadillac DeVille CTS windshield wiper it does nothing no sound no movement what is wrong
Hard to say what's wrong without testing thing's . Is there B+ voltage to the wiper switch ? B + voltage to the wiper motor ? Do you know how to use a voltmeter ? How to test electrical circuits ?
Here is a factory service manual list of componets involved .
Wiper/Washer System Components
The Wiper/Washer System consists of the following electrical components:
• Accessory relay
• Heated washer nozzles w/XA7
• WASH NOZ 10A fuse
• Windshield washer fluid level switch
• Windshield washer pump motor
• Windshield wiper motor
• Windshield wiper motor module
• Windshield wiper/washer switch
• Wiper/washer switch 10A fuse
• Wiper motor 30A fuse
Do you know how the wipers work ?
Windshield Wiper Motor Wiring Tutorial
Wipers Inoperative - All Modes ?????
Wiper Motor Switch Troubleshooting
2helpful
2answers
Rear wiper stopped but can hear motor working, also hear motor when ignition is turned on
the inside of the wiper could be stripped out and have no tension to move the wiper try pulling it off and changing it if not need to see how to take it of and maybe the motor could have stripped the gears inside itself.
Replacing wiper linkage
WINDSHIELD WIPERS
It can be faulty wiper motor or blown wiper control fuse.
Do you hear any kind of noise when you starter the wiper function. If yes then fuse is ok, but issue is wiper motor.
If no movement at all and no noise then its blown fuse or shorted/loose wiper control wiring: -----
For complete troubleshooting i suggest you few helpful links with accurate solutions.
Click the link below: -------
1993 Ford F350 wipers not working?
http://repairhelpcenter.blogspot.in/2012/02/1993-ford-f350-wipers-not-working.html
How to Replace a Windshield Wiper Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-windshield-wiper-motor.html
Wipers not working, but hear relay click on Lincoln LS?
http://schematicsdiagram.blogspot.com/2011/12/wipers-not-workingbut-hear-relay-click.html
Car windshield wiper gets power for movement and stops?
http://schematicsdiagram.blogspot.com/2011/12/car-windshield-wiper-gets-power-for.html
How does cars Windshield Wiper System Works
http://technoanswers.blogspot.com/2011/11/how-does-cars-windshield-wiper-system.html
1997 Honda Protege: Replace Wiper Transmission?
http://technoanswers.blogspot.in/2012/06/1997-honda-protege-replace-wiper.html
Windshield wiper fluid container leaking?
http://whatisbyme.blogspot.in/2012/05/windshield-wiper-fluid-container.html
Where is wiper fuse located on1993 chevrolet suburban
http://technoanswers.blogspot.in/2012/02/where-is-wiper-fuse-located-on1993.html
2002 Toyota Sienna: Wipers and Passenger side Power window stopped working?
http://technoanswers.blogspot.in/2012/04/2002-toyota-sienna-wipers-and-passenger.html
Complete wiper components replacing details for Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/complete-wiper-components-replacing.html
These details will help.
Thanks.
Where is fuse for wiper fluid pump on a 2003 cavalier?
If no movement at all and no noise then its blown fuse or shorted/loose wiper control wiring:-----
Click the link below:-------
Thanks.
How to remove the windshield cowl on a 2002 tyota yaris
Complete wiper components replacing details ?
Thanks.
2answers
2002 intrigue wipers / washer dont work
Do you hear any kind of noise when you starter the wiper function.If yes then fuse is ok,but issue is wiper motor.
------------ How to Replace a Windshield Wiper Motor
Thanks.
Sometime the windshield wipers work and sometimes
It sounds like the wiper motor has a bad gear. Replace the motor and it should solve your problem.
Rear windshield washer motor works, but no fluid comes out
Rear washer may have it's own reservoir . Can you hear a pump humming when you activate the washer? Look in the under flooor compartment
Rear windshield wiper
Try tightening the bolt that holds the wiper in place. There is a cap over it at the base of the wiper where it attaches to the window pop that cap and you will see the it.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
