Question about 4moms Origami Stroller
My 4moms origani model model 4m-006-01 does not fold down automatically I have to do this manually is there a way to fix this
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
How can i open the trunk from inside a running buick regal 2011?
If that model has a fold down section of the rear seat back, the manufacturer normally installs an accessible manual boot release tab in the vicinity of the fold down seat section just inside the trunk compartment.
If there is no fold down seat in that model or no manual boot release inside the trunk area, the rear seat needs to be removed so that you can access the trunk from inside the car.
Nov 11, 2015 | 2011 Buick Regal CXL
Folding down a BladeZ treadmill
Dear Sir:
I recommend that your Read your user manual. Please see this video too for to Help.
http://www.youtube.com/watch?v=kDNegYEnrSc
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 11, 2012 | Exercise & Fitness
How do i fold this puschair up & how does it fold down? Can this done by one person? Thnk you for any help.
The Tracker is designed to be folded and unfolded easily, by one person.
To unfold: If your Tracker has an adjustable handle, ensure that it is in one of the middle positions. On the central twist grip, push in the red button and turn the grip in the direction of the "FOLD" arrow. The pushchair should now begin to open. Placing your hand on the side moulding, pull on the handle until the primary locks on both the left and right hand sides engage with a click. The secondary lock should automatically engage.
To fold: First of all, make sure that the front wheels have been locked into fixed, non-steering mode. Also, ensure that the adjustable handle is in one of the middle positions. Press the red button on the twist grip and simultaneously turn it in the direction of the "FOLD" arrow. At this point, the chair should start to close. Next, look for the secondary locking device. This plastic tab should be situated just below the handle grip on the left-hand side. Pull it upwards, whilst tilting the chassis forwards and continuing the folding action until it is fully closed. Align the front wheel with your foot, if necessary, and fold down the adjustable handle to store the chassis.
Find out more by obtaining an instruction manual from service@bebecar.co.uk
Aug 31, 2010 | Bebecar Tracker Urbano 1455-U Stroller
Can't get sides to stay up (lock) on our Century fold n go lullaby center
I had the same problem until I found the manual and practiced a bit, When opening, it's important for the middle to still be in a high unlocked position - then they click right in place very easily. The sides won't go up if the center column is down too far first because the middle locks in place automatically and prevents movement of the sides.
When folding it, the floor lock has to be twisted fully in the unlock position and the center column back up in a high position for the sides to fold in (each side as 2 joints to disengage). Unlocking turns the center support column so that all the support tubing underneath can move. If the center column won't come up high, you don't have it unlocked yet.
Here's a Century Fold N Go instruction manual.
http://www.gracobaby.com/Instruction%20Manuals/archive/10765.pdf'
To look for different models
http://www.gracobaby.com/customerservice/productinstructions/Pages/default.aspx
Jul 28, 2009 | Baby Gear
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
4moms Origami Stroller Logo
53 people viewed this question
Top 4moms Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a 4moms Baby Gear Expert? Answer questions, earn points and help others
