Question about Hotpoint RGB745 Gas Kitchen Range
Igniter glows all the time
I have a Hot Point gas oven. Any time the oven is plugged in the igniter glows even if the oven is in the off position. Is this a problem in the switch\temp dial?
    President:
  • Hotpoint Master
  • 2,651 Answers
Not necessarly, it sounds as if you may have a short in the wire leading to the ignitor itself ir there exposed wired from ignitor hittting the wall of\r floor it will glow continiously
Posted on Jan 23, 2009
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Apr 01, 2010 | Tappan TGF363 Gas Kitchen Range
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
VDGO viking gas oven upper won't heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
Tappan #tgf605wfw5: igniter gets hot but gas valve does not open up. Part of the igniter bad, or the valve bad. How to check to see which one is bad?
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
My oven doesn't work but the burners do, what's up with that?
I was looking for a solution to my problem. In reading the comments, I can probably provide more information than is given here. My Kenmore gas oven won't ignite. I have over 25 years as an electronics techincian so I am very aware of lethal voltages. I unplugged my stove, it is a 120 volt model. After pulling the panel off so I could get to the thermostat which is the piece the knob goes on, I plugged the stove in and checked to make sure I have 120VAC to the thermostat. I have a red wire which has 120Vac, the thermostat probe wires, and a yellow wire which goes down to the back of the oven.
My red wire had 120Vac. I then unplugged the stove, very important at this point, and meaured with an ohmmeter across the yellow and red wires. When the oven is in the off position this is open. When I turn the oven on it is shorted. That should confirm the thermostat switch works. The next thing that has to happen is the glow bar/igniter has to glow. This is like all gas appliances, it has to glow to heat the gas valve and turn the gas on. My igniter doesn't glow so I ordered a new igniter. If your glow bar glows, it could still be the glow bar/igniter or the gas valve is not allowing gas to flow even after it is heated up.
If anyone sees a problem with this procedure, please let me know.
Nov 19, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven burner delays too much to light
Zanes, Your oven igniter is getting weak. The glowing bar next to the manifold must draw between 2.7 and 3.3 amps before the safety valve will acknowledge that it's actually hot enough to ignite gas and open up. Your igniter is most likely right at ~2.5 amps and the valve is "wanting" to open, but won't without some persuasion (hammer anyone?). The part number for your igniter is 9753108 and is available. Your local appliance parts house may not carry it, but there is a substitute that they WILL carry. Its' part number is WB2x9998. It's a universal flat igniter. Unplug the oven before repairing it, OK?
Aug 01, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
95 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
