Question about Dell Dimension 2400 PC Desktop
Dell 2400 freezing upon startup
Hi there. i have a rather old Dell Dimension 2400 desktop. it's been in storage for about a year, and now i'm trying to get back into it. upon startup, it simply freezes. it even freezes in safe mode. i think some old programs are trying to start themselves up, but i think too many try to start up at once, and they all just freeze each other out. don't know what to do, can't junk this thing until i get some files.
    Novelist:
  • 136 Answers
Hi there You can try this steps Start-Run-MSCONFIG and click on STARTUP and click on disable all.Make sure to check the option which is related to Anti-Virus. Also you can try by running disk cleanup(cleanmgr).Also you can run disk defragmentation. This will make the computer better. But if you still want to make it faster,you can modify the registry settings with your own risk.Start-Run-regedit HKEY_LOCAL_MACHINE\SYSTEM\Control Set\Current Control Set\Waittokillservice,by modifying the value will make the computer better.
Posted on Jul 18, 2007
  • 4 Answers
Hi, Try this: Choose last version correct from the start up menu.
Posted on Jul 07, 2007
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
I have forgotten the Administrator Passowd on my Dell Dimension 2400 PC
Hi
Just open your CPU,then look for the battery number 2025,then take it out for 5 minutes,and put it back. The purpose of taking out the battery is to reset the password back to its default.
Regards:
votit
Jan 24, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 with a blinking amber light what do i do
The blinking amber light on the dimesion 2400 generally means that the power supply on the system has gone bad. Switch off the system and disconnect the power cord from the back of the system . Press and hold down the power button in the front for 10 seconds.
Reconnect the cable back and try powering on the system.
If the same ,fails you would have to take the system in for repairs
Thanks for using Fixya
Proton
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
I have a six year old Dell, do I need to shut off Windows Update for XP? Someone told me it is not necessary?? Worried Grandma
Hi:
You should keep the windows update on and running. It will not hurt anything, and usually keeps your windows security up to date, for free!
Feb 10, 2010 | Dell Dimension 2400 PC Desktop
I cannot play a DVD on my Dimension 2400. I can
Oops... Man sad but True, it isn't a DVD ROM, if it says CD-RW.
Regards,
Waqar.
Aug 17, 2009 | Dell Dimension 2400 PC Desktop
Desktop screen won't stay on
how old is your screen, if its older than 2-3 years mostly its gone and you need to replace it. If its in warranty then contact dell customer support. Life of screen can be around 3 years after that i may not work.
Another test is to connect it to some other computer and see if its working, then we can focus on some output issue from the CPU.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
My dell dimension 2400 does not recognize the dvd wr when I try to burn a back up dvd
The dvd drive is faulty, the same thing happen to me, Took the dvd drive to work tested it on a different pc and it did not work, go a old dvd drive from work installed it and it worked.
Your dvd is faulty needs replacing
Mar 25, 2009 | Dell Dimension 2400 PC Desktop
Trying to get wifi for Dell Dimension 2400
Less expensive for recieving is simply the "usb stick" I would recommand a "ralink" chipset, (can be found in USROBOTICS and some less expensive brand like TOPLINK
Nov 26, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
128 people viewed this question
Clive
Clive
Alun Cox
