Question about Sharp AL-1641CS Laser Digital Copier
Sharp ar-207 blinking l6 error
I have sharp ar-207 with blinking l6 error please help
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
  • 61 Answers
SOURCE: error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Posted on Jan 22, 2008
M2Tech1
  • 313 Answers
SOURCE: Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Posted on Jul 01, 2009
  • 16 Answers
SOURCE: SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Posted on Jul 07, 2009
  • 990 Answers
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Posted on Aug 19, 2009
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
AR 207 copier with code L6
L means LASER UNIT is defective
Apr 06, 2010 | Sharp AR-207 Copier
Sharp AR 207 displaying L6-10
HI for L6-10 you must change the polygon motor and if you are unlucky may change all the laser unit but usually with the polygon motor it is ok
Mar 22, 2010 | Sharp AR-207 Copier
Aug 19, 2009 | Sharp AR-M205 Copier
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error Code E 7
press"clear","interupt","0","interupt",enter14 press start.should take care your problem.
Dec 15, 2008 | Sharp AR-207 Copier
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Problem with copier SHARP AR-206 display
what is the problem with the display ? is it out ? or showing an error ?
Apr 05, 2008 | Sharp AR-207 Copier
My sharp ar-207 is flashing an L6
This is a polygon motor lock error (LSU).....This is a very good job if you never did it. You may wan't to service it or at least get a estimate...
Good lock !
Apr 04, 2008 | Sharp AR-207 Copier
Sharp AR-5316, showing L6 on display
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1641CS Laser Digital Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
