Question about Frigidaire GLEFM385D Electric Kitchen Range
Cooking pizza and my son locked door
The door is locked and i can not open it to get there dinner out....please help. i try to use the timer method but the oven does not have a clear off button i also turn the oven off by the fuse box with no results.
  • escott02 Jan 23, 2009
    there is no clear/off button on the panel
  • v_mertz Feb 04, 2009
    STARTED SELF CLEAN STOPPED IT BUT NOW THE DOOR IS LOCKED IT HAS BEEN OVER 24HRS
  • 15,935 Answers
To cancel the Oven Lockout feature, press and hold CLEAR/OFF button for 3 seconds. The control will unlock the oven door and
resume normal operation.
Posted on Jan 23, 2009
  • blueextc3221
    blueextc3221 Jan 23, 2009
    HERE is your owners manual - the solution I gave above can be found on page 12.
    Than you for using FixYa, a FiXyA rating is appreciated!!
Bake pizza
I would check the cooking instructions on the outside of the pizza packaging. If microwave cooking is not a suggest method I would not try to cook it in a microwave.
Mar 20, 2014 | Panasonic Microwave Ovens
We are renting a new place and the previous owners did not leave the instruction manual for the frigidaire self cleaning convection oven. we were cooking dinner tonite, and when i went to check it, the...
Possible cause: inlet valve, pressure switch or control board failure.
Possible solution: Do not open door, select drain/spin to remove water, restart cycle.
I also found a listing that says e45 is a bad control board.
I would look inside the washer for a wiring/diagnostic sheet that will give the test procedures.
May 14, 2011 | Kitchen Ranges
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
Jul 21, 2010 | Crosley CE35111AA Electric Kitchen Range
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Our oven door is locked. We were cooking a pizza. There is no way we can figure out how to unlock the door.???
Try turning off the power to the appliance for about 30 minutes, then turn it on again and see if the door releases. This is sort of like "re-booting" a computer.
You can also try to open the door after the power is turned off, but don't get too rough.
If no luck there is a mechanical issue with the latch or possibly a relay issue with the control board.
Jan 27, 2010 | Ovens
After using my electric range self cleaning oven an f90err appeared and the door will not open. I would really like to cook my new years dinner .Can you help please ?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Dec 31, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire GLEFM385D Electric Kitchen Range Logo
189 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
