Question about KitchenAid Microwave Ovens
How to replace the light bulb on the kitchenaid microwave oven model kbms1454
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
Mar 14, 2015 | KitchenAid KCMS1555SSS Microwave Oven
How do you change the bulb in a Kitchenaid microwave Model KBMC140HSS03
Hello & Welcome to FixYa
To replace the light bulb first remove the screws located on the vent grill at the top of the microwave, tilt the grill back and then pull away to remove. After this open the light cover , you have to remove the screws so that you can discard the old light bulb and then replace it with a new one. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Jun 30, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave bulb replacement
The oven will need to come down from the wall so the outer cover can be taken off. Then you'll see the light socket(s).
It's recommend due to the weight and awkwardness of the oven that two people do this job.
If you don't still have your installation instructions, you can download them here, but you should use you full model number, as opposed to the base KEM378.
This uses a fairly common halogen bulb, but I'm not sure of the wattage. It should be marked on the bulb or on a tag near the reflector.
Aug 30, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
54 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
