Question about Cameras
I have the canon power shot 590 digital camera i keep getting the message CHANGE THE BATTERIES I CHANGE THE BATTERIES AND I GET THE SAME MESSAGE IS IT THE AMERA OR THE BATTERIES? ANN
    Brigadier General:
  • 5,158 Answers
Are you changing them with top quality alkaline batteries... digital cameras basically eat batteries and you should invest in some rechargable batteries for it.
Robert
Posted on Jan 23, 2009
I have often bought several rechargable batteires but they as soon as I recharge i get low battery message. A 590 IS
I hate to ask, but did you insert them the right way? Test the batteries in a flashlight. Test the camera with Alkaline batteries. That will isolate the problem. The other possibilities are dirty or corroded contacts.
Sep 23, 2010 | Canon PowerShot A590 IS Digital Camera
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
CAMERA battery low message with new batteries
I have the same problem with mine!! Had it about 14 months now too!! Glad I'm not the only one... I don't know what to do! I have gotten brand new rechargeable batteries and instead of getting 250 shots, I only get like 20!
Dec 17, 2008 | Canon PowerShot A650 IS Digital Camera
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
Aug 28, 2008 | Canon PowerShot A400 Digital Camera
Change batteries message pops up with new batteries
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Jun 23, 2008 | Canon PowerShot A85 Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Lens
The Lens drive is shot Canon customer support will advise I my opinion if the camera is more than a year or so old the repair cost will be high.
Aug 01, 2007 | Canon PowerShot S3 IS Digital Camera
Change Battery Message
Clean the battery contachs- use a pencil eraser to get at those in the base of the chamber. Then try. Some timer the cap that closes the battery chamber is no longer making tight contact- keep it pressed in with a finger when taking shots. If all this is to no avail get onto Canon Technical Support.
Nov 14, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Cameras Logo
167 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
